2008 infiniti pts m35
triniforever
Copper - Posts: 323
Posted: January 03, 2013 at 3:11 PM / IP Logged
Hey guys ,I need some help ,I recently installed a Viper remote start and keyless entry with an Idatalink module flashed with the latest firmware on this vehicle ,everything works fine except the takeover part, whenever the car is remote started and the doors or should I say the driver door is unlocked with the factory or aftermarket remote and when the vehicle is entered and the door is closed the remote start shuts down in like two seconds,so key takeover does not happen and I can't figure out why. Maybe I am missing something any help is appreciated .................thanks..........Triniforever
triniforever
Twelvoltz
Platinum - Posts: 2,384
Posted: January 06, 2013 at 8:34 AM / IP Logged
Did you connect the GREEN/ red from the ADS module to ground? This would cause the problem you're describing.
