remote start, 07 tacoma
clemsonscj
Member - Posts: 30
Posted: January 25, 2013 at 11:29 PM / IP Logged
Putting a remote start/security system in my 07 Tacoma. What is the dome light supervision? Is it worth hooking up?
Posted: January 25, 2013 at 11:58 PM / IP Logged
No. If the vehicle's dome light stays on for up to a minute after you shut the door but shuts down immediately you lock it then like most Toyotas you already have it and you connect the alarm NEG door trigger to the wire marked dome supervision.
clemsonscj
Member - Posts: 30
Posted: January 26, 2013 at 12:04 AM / IP Logged
So I can hook the door trigger to the dome light wire as a door monitor?
Posted: January 26, 2013 at 12:13 AM / IP Logged
Yes, providing it already works as I described above.
clemsonscj
Member - Posts: 30
Posted: January 26, 2013 at 12:18 AM / IP Logged
That is how it works, but I thought the door trigger is a neg input and the dome light is positive. Maybe it's neg though idk
Posted: January 26, 2013 at 12:27 AM / IP Logged
No such thing as maybe, TEST, OK I'm winding you up.
Blue (-) NEG dash fuse box, black 13 pin plug (1E), pin 9.
clemsonscj
Member - Posts: 30
Posted: January 26, 2013 at 12:37 AM / IP Logged
Ok I just didn't have the manual in front of me here. But I'll be metering everything when I do it tomorrow.
Posted: January 26, 2013 at 12:51 AM / IP Logged
Good, with out trying to sound facetious, patronising or condescending please please re-read my signature line. remote start, 07 tacoma -- posted image.
We get more problems arising from people assuming and not testing than anything else.
clemsonscj
Member - Posts: 30
Posted: January 26, 2013 at 7:50 AM / IP Logged
I'm in the middle of hooking up a remote start on my 07 Tacoma. I'm getting confused by the wording on the Viper harness diagram, so I need some quick help. Can you take a look at these 2 links, one being the wiring for my Tacoma and the other being the install instructions for the Viper unit, and let me know which wires go to which between the 2 (only for the 10-pin heavy-gauge remote start harness):
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp (you'll have to select "Toyota" and then scroll down to where it says "2005-2008" under Tacoma)
http://www.12voltdistributors.com/wp-content/uploads/2012/09/Viper_5904V_Installation_Guide.pdf
Thanks in advance.
Platinum - Posts: 7,828
Posted: January 26, 2013 at 8:09 AM / IP Logged
H3/1 PINK (+) IGNITION 1 INPUT/OUTPUT          BLACK/ red (+)  ignition switch, white 8 pin plug, pin 6
H3/2 RED / WHITE (+) FUSED (30A) IGNITION 2   WHITE/ red (30A) (+)    ignition switch, white 8 pin plug, pin 5
H3/3 ORANGE (+) ACCESSORY OUTPUT            WHITE/ green  +  ignition switch, white 8 pin plug, pin 2
H3/4 VIOLET (+) STARTER OUTPUT (CAR SIDE) GREEN/ black  +  ignition switch, white 8 pin plug, pin 7
H3/5 GREEN (+) STARTER INPUT (KEY SIDE)    GREEN/ black  +  ignition switch, white 8 pin plug, pin 7
H3/6 RED (+) FUSED (30A) IGNITION 1 INPUT       WHITE/ red (30A) (+)    ignition switch, white 8 pin plug, pin 5
H3/7 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT          blue / YELLOW  +  ignition switch, white 8 pin plug, pin 1  *** Set to IGN2
H3/8 PINK/BLACK (+) FLEX RELAY INPUT 87A
H3/9 RED / BLACK (+) FUSED (30A) ACC/STARTER INPUT          WHITE/ red (30A) (+)    ignition switch, white 8 pin plug, pin 5
H3/10 NC (no connection)
You will need an additional 30/40 Amp SPDT relay with 20 Amp fuse to power the Tacoma's Starter2 circuit.  Wire as follows :
Relay Pin 85 to Viper Purple (-) 200mA Starter Output ( thin wire )
Relay Pin 86 and 87 to +12V constant (  WHITE/ red (30A) (+)    ignition switch, white 8 pin plug, pin 5 ) thru 20 Amp fuse
Relay Pin 30 to Tacoma  BLACK/ white (+)  ignition switch, white 8 pin plug, pin 3
Relay P{in 87A  not used - insulate
Page of 7
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
