1973 Porsche 911T
draasch
Gold - Posts: 2,172
Posted: May 09, 2003 at 12:39 PM / IP Logged
does anyone have any wiring info on this car?????????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
the12volt
Administrator - Posts: 3,959
Posted: May 09, 2003 at 1:02 PM / IP Logged
No, but everything should be easy to figure out with your meter. Lights will likely be left and right instead of one for both and can be caught at the fuse/relay panel under the hood. Everything else should be relatively easy with the exception of finding a decent spot to hide the siren where it won't be exposed to heat or weather, but if you have the room, the best place has typically been in the rear of the vehicle high on the firewall.
1973 Porsche 911T -- posted image. the12volt • Support the12volt.com
the12volt
Posted: May 09, 2003 at 1:10 PM / IP Logged
