2013 dodge dart remote start
Raymond4646
Copper - Posts: 121
Posted: June 04, 2013 at 12:28 AM / IP Logged
Looking for a remote start wiring guide for this vehicle. Have not been able to find anything. Any issues with this vehicle?
tonanzith
Gold - Posts: 603
Posted: June 04, 2013 at 12:38 AM / IP Logged
Not certain if you need a bypass module. None are listed.
Second 12 Volts     N/A
Starter     dk. blue/brown     -     BCM under driver dash, 60 pin plug (C4), pin 49
Second Starter     PURPLE / brown Ignition Node Module, white 6 pin plug, pin 4
Ignition     pink/white     +     BCM under driver dash, 60 pin plug (C8), pin 48
Second Ignition     brown     +     BCM under driver dash, 60 pin plug (C4), pin 3
Third Ignition     N/A
Accessory     BROWN / white     -     BCM under driver dash, 60 pin plug (C4), pin 4
Second Accessory     lt. GREEN/ dk. blue     -     BCM under driver dash, 60 pin plug (C4), pin 10
Third Accessory     N/A
Keysense     N/A
Data Bus     WHITE/ lt. green (security K Line)     data     Ignition Node Module, white 6 pin plug, pin 5
Can Bus High     brown (CAN C bus)     data     BCM under driver dash, 60 pin plug (C4), pin 38
Can Bus Low     yellow (CAN C bus)     data     BCM under driver dash, 60 pin plug (C4), pin 37
Can Bus Sw     N/A
Power Lock     PURPLE / dk. green     - 300 ohms     BCM under driver dash, 60 pin plug (C6), pin 27
Power Unlock     same as power lock     - 100 ohms
Lock Motor     lt. GREEN/ dk. blue     5 wire     BCM under driver dash, 32 pin plug (C5), pin 18
Driver Unlock Motor     BROWN / lt. green     5 wire     BCM under driver dash, 32 pin plug (C5), pin 32
Passenger Unlock Motor     tan     5 wire     BCM under driver dash, 32 pin plug (C5), pin 3
Parking Lights (-)     WHITE/ brown (need to relay isolate the switch)     -1130 ohms     headlight sw or BCM under driver dash, 60 pin plug (C8), pin 42
Parking Lights (+)     WHITE/ yellow (L); WHITE/ gray (R)     +     BCM under driver dash, 60 pin plug (C6), pins 47 and 3
Hazards     WHITE/ dk. blue     -     BCM under driver dash, 60 pin plug (C8), pin 55
Turn Signal (Left)     WHITE/ lt. green (F); WHITE/ dk. green (R)     +     BCM under dr dash, 60 pin plug (C4), pin 31; 60 pin plg (C6), pin 4
Turn Signal (Right)     WHITE/ brown (F); WHITE/ yellow (R)     +     BCM under dr dash, 60 pin plug (C4), pin 46; 60 pin plg(C6), pin17
Headlight     WHITE/ brown (need to relay isolate the switch)     - 660 ohms     headlight sw or BCM under driver dash, 60 pin plug (C8), pin 42
AutoLights     WHITE/ brown (need to relay isolate the switch)     -2Kohm(off     headlight switch or BCM, 60 pin plug (C8), pin 42
Reverse Light     WHITE/ lt. green     +     BCM under driver dash, 60 pin plug (C6), pin 1
Left Front Door Trigger     purple     -     BCM under driver dash, 60 pin plug (C6), pin 50
Right Front Door Trigger     PURPLE / white     -     BCM under driver dash, 60 pin plug (C6), pin 51
Left Rear Door Trigger     PURPLE / gray     -     BCM under driver dash, 60 pin plug (C6), pin 36
Right Rear Door Trigger     purple / YELLOW     -     BCM under driver dash, 60 pin plug (C6), pin 33
Dome Supervision     yellow/lt. blue     +     BCM under driver dash, 60 pin plug (C6), pin 57
Trunk/Hatch Pin     PURPLE / orange     -     BCM under driver dash, 60 pin plug (C6), pin 35
Rear Glass Pin     N/A
Hood Pin     PURPLE / dk. blue     -     BCM under driver dash, 60 pin plug (C4), pin 8
Trunk/Hatch Release     tan/lt. green     -     release switch or BCM under driver dash, 60 pin plug (C8), pin 16
Trunk Release Motor     lt. GREEN / WHITE     5 wire     BCM under driver dash, 32 pin plug (C5), pin 14
Fuel Door Release     lt. GREEN/ purple     +     driver kick, door harness
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     arms on lock with door open
Factory Alarm Disarm     see disarm no unlock
Disarm No Unlock     Transponder and ignition
Trunk Alarm Shunt     N/A
Tachometer     dk. blue/blk, gray/blk, brn/blk, or blk/red (1.4L)     ac     any fuel injector, black 2 pin plug, pin 1
On 2.0L models, the fuel injectors are BROWN / yellow, BROWN / dk. blue, BROWN / lt. blue, or BROWN / tan. On 2.4L models, the fuel injectors are BROWN / yellow, BROWN / dk. blue, BROWN / white, or BROWN / red.
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     lt. GREEN/ YELLOW     -     clutch switch, 3 pin plug, pin 2
Fuel Pump     black     +     passenger kick, harness to rear
Rear Defroster     dk. blue     - latched     BCM under driver dash, 60 pin plug (C4), pin 19
Mirror Defroster     same as rear defroster
Left Front Heated Seat     (CAN IHS bus)
Right Front Heated Seat     (CAN IHS bus)
Speed Sense     lt. GREEN/ brown     ac     Transmission Control Module, 94 pin plug, pin 85
Brake Wire     dk. green to lt. GREEN/ gray     +     brake switch or BCM under driver dash, 60 pin plug (C4), pin 57
Parking Brake     dk. GREEN / WHITE     -     parking brk sw or BCM under driver dash, 60 pin plug (C6), pin 44
Horn Trigger     gray/black     +     BCM under driver dash, 32 pin plug (C5), pin 30
Wipers     BROWN / white (L), BROWN / lt. green (H)     +     BCM under driver dash, 20 pin plug (C3), pins 9 and 10
Left Front Window (Up/Down)     ORANGE / lt. green - ORANGE / white (base)     A     driver window switch, black 14 pin plug, pins 10 and 9
Right Front Window (Up/Down)     ORANGE / gray - ORANGE / dk. blue (base)     A     driver kick, door harness
Left Rear Window (Up/Down)     ORANGE / white - ORANGE / gray     A     driver kick, door harness
Right Rear Window (Up/Down)     ORANGE / dk. blue - ORANGE / dk. blue     A     driver kick, door harness
Sun Roof (Open/Close)     ORANGE / brown - ORANGE / lt blue (func w/ign on only)     +     electronic overhead module, gray 10 pin plug, pins 7 and 9
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     red     +     radio, 52 pin plug, pin 44 or white 22 pin plug, pin 12
Radio Ground     black     -     radio, 52 pin plug, pin 43 or white 22 pin plug, pin 1
Radio Ignition     (CAN IHS bus)
Radio Illumination     (CAN IHS bus)
Factory Amp Turn-on     (CAN IHS bus)
Power Antenna     N/A
Left Front Speaker (+/-)     gray/purple - gray / YELLOW     +,-     radio, 52 pin plug, pins 47 and 51, or wht 22 pin plug, pins 22 and 21
On models with amplifier, the speaker wires are gray/purple - gray / YELLOW at the amplifier behind glove box, black 16 pin plug, pins 8 and 16. The tweeter wires are gray/orange - gray / YELLOW at the amplifier, white 22 pin plug, pins 20 and 9.
Right Front Speaker (+/-)     dk. GREEN/ purple - dk. GREEN/ YELLOW     +,-     radio, 52 pin plug, pins 46 and 50, or wht 22 pin plug, pins 11 and 10
On models with amplifier, the speaker wires are dk. GREEN/ purple - dk. GREEN/ YELLOW at the amplifier behind glove box, black 16 pin plug, pins 7 and 15. The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, white 22 pin plug, pins 19 and 8.
Left Rear Speaker (+/-)     gray/lt. green - gray/dk. green     +,-     radio, 52 pin plug, pins 48 and 52, or wht 22 pin plug, pins 20 and 19
On models with amplifier, the speaker wires are gray/lt. green - gray/dk. green at the amplifier behind glove box, white 22 pin plug, pins 10 and 21. The tweeter wires are dk. GREEN/ brown - dk. GREEN/ gray at the amplifier, black 16 pin plug, pins 13 and 5.
Right Rear Speaker (+/-)     dk. green - dk. GREEN/ gray     +,-     radio, 52 pin plug, pins 45 and 49, or wht 22 pin plug, pins 9 and 8
On models with amplifier, the speaker wires are dk. green - dk. GREEN/ gray at the amplifier behind glove box, black 16 pin plug, pins 9 and 1. The tweeter wires are dk. GREEN/ brown - yellow/gray at the amplifier, black 16 pin plug, pins 4 and 12.
Center Channel (+/-)     gray/brown - gray/orange     +,-     amplifier behind glove box, white 22 pin plug, pins 11 and 22
Subwoofer (+/-)     gry/brn - dk. grn/brn(1); gry/wht - dk. grn/wht(2)     +,-     amplifier behind glove box, blk 16 pin plug, pins 14 and 6; 3 and 11
Aux. Audio Input Left (+/-)     lt. GREEN/ tan - lt. GREEN/ dk. blue     +,-     radio, 52P plug, pins 16-7 or 22P plug, pins 3-4
Aux. Audio Input Right (+/-)     lt. GREEN/ lt. blue - lt. GREEN/ dk. blue     +,-     radio, 52P plug, pins 6-7 or 22P plug, pins 2-4
RSE Video (+/-)     dk. GREEN/ brown - dk. GREEN/ org (rear view camera)     +,-     radio, black 22 pin plug, pins 15 and 16
RSE Audio Left (+/-)     dk. GREEN / WHITE - gray/orange (CD changer audio)     +,-     radio, black 22 pin plug, pins 13 and 1
RSE Audio Right (+/-)     gray/white - gray/orange (CD changer audio)     +,-     radio, black 22 pin plug, pins 14 and 1
Satellite Radio 12 Volts     N/A
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker     6 x 9 left front door
Left Front Tweeter     2.5 or 3.5 left front dash
Right Front Speaker     6 x 9 right front door
Right Front Tweeter     2.5 or 3.5 right front dash
Left Rear Speaker     6 x 9 left rear door
Left Rear Tweeter     3.5 left rear deck
Right Rear Speaker     6 x 9 right rear door
Right Rear Tweeter     3.5 right rear deck
Center Channel     3.5 top center of dash
Subwoofer     8 center of rear deck
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Gary Sather
cmk0808ny
Copper - Posts: 203
Posted: June 04, 2013 at 8:02 AM / IP Logged
Fortin Evo All will do the bypass. and give tach, door locks, factory alarm etc.
Raymond4646
Copper - Posts: 121
Posted: June 04, 2013 at 1:51 PM / IP Logged
Guys thank you very much!! I was considering using the EVO all  are they solid units?
cmk0808ny
Copper - Posts: 203
Posted: June 04, 2013 at 2:20 PM / IP Logged
yup bulletproof
reisset
Member - Posts: 38
Posted: June 06, 2013 at 3:57 PM / IP Logged
Be sure you have a Flash-link updater. You need to crack the key using the Dcryptor.
reisset
Member - Posts: 38
Posted: June 06, 2013 at 3:58 PM / IP Logged
if you install with a EVO-ALL
Raymond4646
Copper - Posts: 121
Posted: June 07, 2013 at 12:55 AM / IP Logged
Good to know the evo all is legit.. Ordered a flash updater 2.. tell me more about decrypter? are you just referring to that's what the flash updater does?
Havent even looked at the door jams. Considering installing a 530t to control all 4 windows for closure.. How is running wires to the door switches?
racerjames76
Silver - Posts: 581
Posted: June 07, 2013 at 10:08 AM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp~TID~78731~PN~1
More than likely you will encounter something similar to this as far as wiring into the doors. ROYAL PITA.2013 dodge dart remote start -- posted image.
To master and control electricity is perfection. *evil laugh*
Platinum - Posts: 7,827
Posted: June 07, 2013 at 6:45 PM / IP Logged
D-Cryptor is Fortins' new process to load the bypass module with the captured transponder info. After the
initial program flash, you you will see that the bypass module is installed / connected to the vehicle, a few steps
are performed with the key in the ignition switch and then the bypass module is removed from the vehicle and
re-connected to the Flashlink2 updater / PC / internet connection for a little "massaging" before being re-connected
to the vehicle for final programming.
The "massaging" is the D-Cryptor process.
Sunday, November 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
