autopage rs720
cairo0203
Member - Posts: 12
Posted: June 27, 2013 at 7:28 PM / IP Logged
Hi guys,
I’m in need of a little bit of help with my RS720 install. I have already installed the correct wire to the appropriate locations (just for the remote start so far). However, after reading the installation manual, I am a little confused on how I can go about installing my transponder that I have purchased. I have a 2000 Nissan Altima with a chipped key that is already programmed to the vehicle. Any feedback would be much appreciated. Thanks
Amr
Posted: June 28, 2013 at 6:28 AM / IP Logged
Is the transponder by-pass a key in the box device?
cairo0203
Member - Posts: 12
Posted: June 28, 2013 at 7:13 AM / IP Logged
Correct, it is the one that I would have to put in a box.
Amr
Platinum - Posts: 7,827
Posted: June 28, 2013 at 8:09 AM / IP Logged
The Brand and Model number would help as each one is slightly different. Might be a Directed 556UW or something like that.
cairo0203
Member - Posts: 12
Posted: June 28, 2013 at 8:57 AM / IP Logged
Here is what I have with the below link. I would rather be extra careful before wiring it up. I get that I need to connect it to the constant 12 volts. However, im a bit confused about connecting to a third ignition.
http://www.directedstore.com/manuals/20402.pdf
Amr
Posted: June 28, 2013 at 9:43 AM / IP Logged
Third ignition would be a NEG ground when running, A.K.A. status output or wire.
lucasoil4u
Copper - Posts: 317
Posted: June 28, 2013 at 11:27 AM / IP Logged
Why use a key in box? There is so much better out there. Please explain.
cairo0203
Member - Posts: 12
Posted: June 28, 2013 at 2:55 PM / IP Logged
Thats what my research kicked back at me (transponder that needs an extra key). What is out there? Currently all my car dash does is the dash would flicker and not start at all.
benzo33
Copper - Posts: 87
Posted: July 01, 2013 at 4:42 AM / IP Logged
There is idatalink which you could hardwire or uses D2D. Rather than leaving a key under the dash.
2001 Corolla S and 2005 Neon SRT 4 ACR.
lucasoil4u
Copper - Posts: 317
Posted: July 12, 2013 at 10:53 AM / IP Logged
Idatalink would be the way to go. That way you dont loose a key and if you ever need to add keys you dont have to take the key out of the box. Also the data bypasses are a lot lower current draw when sitting idle.
Thursday, July 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
