clifford remote keyless entry system need
monette999
Member - Posts: 9
Posted: September 26, 2013 at 1:55 PM / IP Logged
Clifford Remote Keyless Entry System need PlainView coded valet switch schematic
Dear All,
My name is Bob
I have an old 1997 Clifford Remote Keyless Entry System which lost the memory
after disconnecting the battery.
I am trying to relearn the remotes but the system was delivered without the PlainView coded valet switch.
So I would like to build a switch. The switch is special.
Position 1) Latched
Position 2) Center
Position 3) Spring loaded momentary
Than there is an LED as well.
I have four wires 2 by 2 male connectors for the LED and Valet switch.
Connector one
Black ( Ground ) ?????? for LED & Valet switch
RED (12) 5A fuse
Connector two
White (Valet white)
Violet (LED violet)
I would be great if somebody could explain me the function of the PlainView coded valet switch schematic and how should I build a replacement switch.
What is the input and how to wire ground and 12V
Thank you in advance
Bobclifford remote keyless entry system need -- posted image.
monette999
Member - Posts: 9
Posted: September 27, 2013 at 10:16 AM / IP Logged
bump
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
