Need help with Delta pro 5005
jb03
Member - Posts: 15
Posted: May 13, 2003 at 8:41 PM / IP Logged
I recently purchased a delta pro 5005.  I have everything installed but the door locks and the trunk release.  Having a problem with the reverse polarity thing I think.  My vehicle is a 1994 Gmc Yukon and I dl'd the diagrams from this site but still not working.  I hooked the Red wire from the alarm to the orange wire in the doorlock harness.  The light blue in the harness to the Green on the alarm and the BLACK/ White on t harness to the Blue on the alarm.  It's not working????  I noticed on the provided diagram from this site that where it says door unlock its reverse polarity.  Is there something I missed there??  With the trunk release I went from the back of the switch and tried both the orange and the brown wire with no luck.  On the diagram it said wire was to be BLACK/ white but didn't see that there.  With this alarm it says all relays are built in and they are - outputs.  Your help would be greatly appreciated.  Jody Barnes
jb03
Member - Posts: 15
Posted: May 13, 2003 at 8:47 PM / IP Logged
Sorry this is the link I looked at for the diagram:https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1994&make=GMC&model=Yukon%204WD&ID=17946&type=Alarm Jody B
draasch
Gold - Posts: 2,172
Posted: May 13, 2003 at 8:55 PM / IP Logged
Power Lock LT BLUE DRIVER KICK PANEL BELOW #203
Power Unlock BLACK/ WHITE OR BLK/RED DRIVER SPEAKER
are you using relays????
what is the door lock outputs on the alarm??
Trunk Release BROWN (+) AT REAR GLASS RELEASE SWITCH #231
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
jb03
Member - Posts: 15
Posted: May 13, 2003 at 9:48 PM / IP Logged
No I didnt think I needed to use relays because it says they are built in.  The outputs on the alarm are negative and had a ?  What does the #203 and #231 mean??  Thanks for your help
jb03
Member - Posts: 15
Posted: May 13, 2003 at 9:51 PM / IP Logged
OOOps it says Red---(+) 12v. out for the door locks
