viper 5904v led
namyenruoj
Copper - Posts: 86
Posted: October 02, 2013 at 10:32 AM / IP Logged
I just recenly finished installing a viper 5904V on my 91 celica. My LED from transponder was working fine las week and now it's not blinking at all when the system is armed. Is there a way to bring the light back again? Thanks
namyenruoj
Copper - Posts: 86
Posted: October 02, 2013 at 10:37 AM / IP Logged
Everything works i can arm, disarm and remote start it no problem except the light
lucasoil4u
Copper - Posts: 317
Posted: October 02, 2013 at 3:36 PM / IP Logged
Did you check to insure that it is plugged in still?
namyenruoj
Copper - Posts: 86
Posted: October 08, 2013 at 5:55 PM / IP Logged
yah i made sure both side are plugged in still does not work
namyenruoj
Copper - Posts: 86
Posted: November 04, 2013 at 11:49 PM / IP Logged
i sent the tronsponder back and got a new one. i plugged it in the LED still does not blink or light up at all. what could it be the problem is there any alternative to add another LED in the system. thanks
davep.
Gold - Posts: 649
Posted: November 05, 2013 at 8:55 AM / IP Logged
how about test the LED? Keep in mind it is 2V. Unplug it from the module. Fab up some little jumpers. Use a AA battery as a power source. I don't know the polarity offhand, so try both polarities. If neither work, something has happened to the LED or the wiring to it.
namyenruoj
Copper - Posts: 86
Posted: November 06, 2013 at 12:17 AM / IP Logged
the wire cable between the unit and the trransponder 4 wires how can you check it for voltage
namyenruoj
Copper - Posts: 86
Posted: June 21, 2014 at 10:48 PM / IP Logged
Which wire is it from viper 5904v that will give out output voltsge upon disarming so i csn use it for my interior light
Posted: June 22, 2014 at 1:40 AM / IP Logged
Red (+) and pink (-) use a DMM or a 1.5 volt battery, AA. AAA.
If everything works, assume either the LED or the LED driver in the brain.
