starter on 05 express van
kustom2
Member - Posts: 12
Posted: November 13, 2013 at 9:37 AM / IP Logged
Problem with starter on 05 Chevy Express van,
Excalibur RS-350-EDP+, with OL-MDB-ALL.
After install unit would unlock before start and not re-lock after start.
Tried to program lock command to unlock at start and lock after start sequence and dash lit up with (abs and brake lights, they stay on after take over?)
Reset program back to no lock action at startup and key in ign warning bell goes off extra fast.
Reset program back to unlock at startup and dash lights (ABS and Brake still stay on)
So any thoughts on what I did wrong.........?
kustom
skee-weezy
Copper - Posts: 177
Posted: November 13, 2013 at 10:14 AM / IP Logged
Sounds like you may have also accidently reprogrammed the behavior of your ignitions or accessories. I suppose it is also possible that you may not have one or more ign or acc powered up too. As to why it wouldn't relock... no clue. My shop does a ton and I do mean a ton of Omega and never saw one behave in that manner. DOUBLE CHECK your work sir and good luck.
there can be only one.......
kustom2
Member - Posts: 12
Posted: November 13, 2013 at 3:25 PM / IP Logged
understood, I`ll double check and re-program starter to defaults.
kustom
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
