2008 mx 5 , python 5706
finfins
Member - Posts: 6
Posted: December 11, 2013 at 7:47 AM / IP Logged
Hi every one. I installed a Python remote car starter alarm combo in a 2008 mazda Mx-5 (Miata). Everything works except the remote starter. I can : lock,unlock the doors. Open the trunk. Arm, disarm the alarm. I can engage the pit stop fonction. But i CANNOT remote start the car. It will try 3 time and then... pop up Remote start error on my lcd remote.
Here are some program feature:
Set in automatic transmission
set in tach mode (tried injector and coil), tried in voltage mode too
set flex relay to 2nd accessory
else is factory set-up.
i did the learn tach sequence.
There is no power at all on the start ouput relay(violet wire).All 3 inputs red wires (RED / red-WHITE/ RED / black) are connect to a 12v constent voltage source.
Can it be a faulty brain ??? I don't know where to look anymore.
thank you for your Help.
Platinum - Posts: 7,827
Posted: December 11, 2013 at 12:37 PM / IP Logged
What bypass module did you use for the transponder based ignition immobilizer? Have you tried a remote start with a key inserted ( but not turned ) in the ignition switch?
Any error lights on the instrument cluster during a failed remote start attempt?
Have you run the Pythons Shutdown Diagnostics? That error code could help determine a problem,.
finfins
Member - Posts: 6
Posted: December 11, 2013 at 12:51 PM / IP Logged
Hi, i use a expresskit PK transponder. yes i did try the key in the barriel with no success. No light or led different then usual. In the shutdown diagnostic i have a low or no RPM. That is true, the car didn,t crank !!!!
My next step is to use the flex output(set as 2nd starter) to replace the starter output, and/or use the 24pin starter out to energize an external relay.
We will see.
finfins
Member - Posts: 6
Posted: December 13, 2013 at 11:24 AM / IP Logged
i did some test and i found out that the only start output working is when i use the flex output ??? That mean that both Heavy gage starter out and the secondary starter out (24 pin harness) are dead !!!! Look like my module is defective....
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
