viper 5901 aux outputs
antonic
Member - Posts: 14
Posted: December 29, 2013 at 6:15 PM / IP Logged
Is there any problems using these outputs to run relays to fold/unfold side mirrors when arming and disarming instead of using Pulse Timer Relays 528Ts?
I would set them to Timed 30sec and link them to Arm/Disarm?
viper 5901 aux outputs -- posted image.
freqsounds
Copper - Posts: 289
Posted: January 11, 2014 at 6:26 PM / IP Logged
What is the year, make, model of the vehicle?
You can use an aux channel and link to arm and disarm, but I think 30 seconds would be too long. Unless it uses sensors that control the motors (meaning the BCM ultimately controls the fold in/out), I wouldn't hook it up. There may be a wire you can pulse to tell the car to fold them in or out.
antonic
Member - Posts: 14
Posted: January 13, 2014 at 6:23 AM / IP Logged
The car is a 2002 Nissan Silvia(S15). I don't think there are any pulses to fold/unfold them automatically. Hence I have set up 2 relays to run the motors with -ve triggers.
You can set the time to 5s with a Bitwriter, doesn't have to be 30s.
Thanks.
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
