xk06 won't program
jnz1
Copper - Posts: 109
Posted: January 08, 2014 at 6:52 PM / IP Logged
I have an Xk06 pkg7 bypass and have everything hooked up wire to wire, but cannot get the unit to program as per the instructions. The led light comes on when I plug in the 10pin harness, but per programming instructions say to hold the programming button and turn the car on, the led should flash 3 times then release button. Mine the light stays solid while holding the button and I turn the car on nothing flashes just stays solid. I have tried several times. I have reset the bypass and the led confirms this. The only wire I do not have hooked up is orange 12 volt starter in as this is being installed on a 2005 Cobalt with no starter wire. Any help is greatly appreciated
smokeman1
Platinum - Posts: 1,589
Posted: January 08, 2014 at 7:17 PM / IP Logged
Even though you are not using the starter wire from the remote starter on the car, I think the xk06 orange wire needs to be connected to the remote start starter output. What make/model remote start?
jnz1
Copper - Posts: 109
Posted: January 08, 2014 at 7:53 PM / IP Logged
It's an avital 4113 single button unit.
bl4ck3d0ut
Member - Posts: 27
Posted: January 09, 2014 at 10:04 AM / IP Logged
Yes the xk06 orange wire has to be hooked up to the remote starter's starter wire
jnz1
Copper - Posts: 109
Posted: January 09, 2014 at 3:38 PM / IP Logged
I have connected the Orange wire to the starter output of the remote start and nothing has changed still not programming. I know there are two sets of instructions out there each with two different wiring set ups for the xk06. Mine lists programming as
VEHICLE PROGRAMMING:
1) Connect module , LED turns on for 2 seconds, then goes off.
2) Press and hold the programming button, LED comes on.
3) Start vehicle by key, LED will flash 3 times.
4) Release program button. Module is programmed.
jnz1
Copper - Posts: 109
Posted: January 09, 2014 at 3:50 PM / IP Logged
Here Is My Wiring
Main Harness (H1), 9-pin connector
H1/1 LIGHT GREEN BLACK (-) 200mA FACTORY ALARM DISARM � Not Installed
H1/2 GREEN / WHITE (-) 200mA FACTORY ALARM REARM � Not Installed
H1/3 YELLOW (+) IGNITION OUT (TO ALARM) � Not Installed
H1/4 WHITE/ BLUE (-) ACTIVATION INPUT �Not Installed
H1/5 ORANGE (-) 500mA GROUND WHEN LOCKED/ANTI-GRIND OUTPUT �Not Installed
H1/6 BROWN (-) 200mA HORN OUTPUT � To Tan At BCM J2 Connector pin 14
H1/7 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT* -Not Installed
H1/8 BLACK GROUND � To Chassis Ground
H1/9 WHITE (+/-) LIGHT FLASH OUTPUT � To BROWN / White At BCM J2 Connector pin 5
Door Lock - 3 pin connector �Not Used
Heavy Gauge Relay (H2), 6-pin connector
H2/1 PINK OUTPUT TO PRIMARY IGNITION CIRCUIT �To Small Yellow At BCM J4 Gray Connector (Behind fuse box) pin D3
H2/2 PURPLE OUTPUT TO STARTER CIRCUIT �Not Installed
H2/3 ORANGE OUTPUT TO ACCESSORY CIRCUIT �To Small Brown At BCM J4 Gray Connector (Behind fuse box) pin C8
H2/4 RED (+) 30A HIGH CURRENT 12V INPUT �To RED / Black At BCM J3 Connector pin D1
H2/5 PINK/WHITE OUTPUT TO SECOND IGNITION/ACCESSORY CIRCUIT � Not Used
H2/6 RED (+) 30A HIGH CURRENT 12V INPUT �To RED / Black At BCM J3 Connector pin D1
Satellite harness - 4-pin connector
1 BLUE (-) 200mA STATUS OUTPUT �To XK06 Ground When Running Brown
2 ORANGE (-) 200mA ACCESSORY OUTPUT �Not Installed
3 PURPLE (-) 200mA STARTER OUTPUT �To Orange � 12v Starter (Input From RCS)
4 PINK (-) 200mA IGNITION OUTPUT �Not Installed
Remote Start harness (H3) 5-pin connector
H3/1 BLACK/ WHITE (-) NEUTRAL SAFETY SWITCH INPUT � To Chassis Ground
H3/2 VIOLET/WHITE TACHOMETER INPUT WIRE � To BROWN / White At Ignition Coil
H3/3 BROWN (+) BRAKE SHUTDOWN INPUT WIRE � To Lt.Blue At BCM J2 Connector pin 54
H3/4 GRAY (-) HOOD PIN SWITCH SHUTDOWN WIRE �To Hood Pin
H3/5 BLUE/WHITE (-) 200 mA 2ND STATUS/REAR DEFOGGER �To Lt.Blue At BCM J2 Connector Pin 68
XK06 Wiring
Pin 1 Brown � Ground When Running - BLUE (-) 200mA STATUS OUTPUT of RS
Pin 2 Green � Resistor Code Input - White Connector Side Ignition Harness
Pin 3 Blue � Resistor Code Output - White BCM Side Ignition Harness
Pin 4 Violet/White � 12v Output - RED / White Connector Side Ignition Harness
Pin 5 Violet � Data Wire - Green 1st Pin OBDII Connector
Pin 8 Orange � 12v Starter (Input From RCS) � PURPLE (-) 200mA STARTER OUTPUT of RCS
Pin 9 Red � Constant 12v � RED / White BCM Side Ignition Harness
Pin 10 Black - Chassis Ground
smokeman1
Posted: January 09, 2014 at 6:22 PM / IP Logged
Link to expresskit web site. Look up your car and then the xk06 instructions.
http://www.xpresskit.com/VehicleCompatibility.aspx?p=null&year=2005&make=Chevrolet&model=Cobalt&ps=1&s=0&c=0
xk06 Green & WHITE/ Violet to connector side of CUT white wire.
xk06 Blue to Key side of white (cut)
xk06 Pink to Yellow
Xk06 Red to 12v RED / White
xk06 Black to chassis ground
Xk06 orange to H2/2 of remote start unit
xk06 to Brown status output of Remote Starter unit AFTER resistor code is learned
jnz1
Copper - Posts: 109
Posted: January 09, 2014 at 10:28 PM / IP Logged
Thanks bl4ck3d0ut and smokeman1 for your help. I see this issue now is the xk06 I got along with the directions indicate the firmware is pkg7. This explains why my directions weren't matching up with your advice. I'll have this flashed tomorrow with plxr firmware and switch some wires around.
jnz1
Copper - Posts: 109
Posted: January 10, 2014 at 8:47 PM / IP Logged
Had bypass flashed today with plxr v3.0. I plug the bypass in and it flashes three times, I push the programming button twice and it flashes twice then I go to save and exit and the led flashes once, but comes back on solid right after. I turn the key to ignition and hold the button the relay clicks light flashes and goes off. The final step of actually learning the resistor code does nothing happens the led does not respond. It seams the xk06 exits after the first step? Anyone else had this issue. I have two xk06 and have tried both, both do the exact same thing.
smokeman1
Posted: January 11, 2014 at 5:37 AM / IP Logged
Do you still have the brown wire connected when trying to learn the resistor code?
If two modules are doing the exact same thing, something is wired incorrectly.
Page of 3
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
