code alarm ca 5050
Msp541
Copper - Posts: 52
Posted: January 08, 2014 at 10:04 PM / IP Logged
Can anyone help me out with the installer guide for the Code Alarm CA-5050? I would greatly appreciate any help and help for programming 2 remotes to this unit.
Thanks again! code alarm ca 5050 -- posted image.
Thanks, Bri
lectricguy
Copper - Posts: 359
Posted: January 08, 2014 at 10:24 PM / IP Logged
Install Manual link: http://documents.codesystems.com/710877.pdf
The transmitter programming is done as follows:
1. Turn the ignition ON (between Accessory & Start).
2. Press and hold the valet/override button.
3. Within 10 seconds the system will chirp (3) three times.
4. Press 1 button of each transmitter you wish to program. (press the Lock button)
5. The system will respond with 1 chirp for each accepted transmitter.
NOTE: The system will exit transmitter programming after 15 seconds of inactivity.
NOTE: This system has 1 button programming which programs all channels (buttons) of the system on a single press of the transmitter lock button.
NOTE: The system will hold up to 4 transmitters in memory, programming a 5th transmitter will erase the oldest transmitter in memory.
Lectric Guy
