'13 honda accord python dball2
godd dan it
Copper - Posts: 447
Posted: February 02, 2014 at 10:20 AM / IP Logged
I installed a Python alarm/remote starter with the Dball2 in a 2013 Honda Accord. I used D2D for the install and it also required a valet key to be used . I have one issue. I cant unlock the car when it is in remote start mode. I have to put the key in the door cylinder to unlock it. Any ideas what I can do?
Thanks.
godd dan it
Copper - Posts: 447
Posted: February 02, 2014 at 10:25 AM / IP Logged
Also, one more question. The Xpresskit install sheet said to hook up the rearm wire to the parking lights if the car has automatic headlights. What exactly is the rearm wire on the Python alarm/remote starter?
triniforever
Copper - Posts: 323
Posted: February 02, 2014 at 11:00 AM / IP Logged
Where did u get the unlock wire in the car or did you wire the unlock wire to the DBALL?if so try hardwiring the unlock wire to the car and it should work ,the rearm wire on the Python should be a GREEN / WHITE wire on one of the harness cuz you didn't give a model number I can't say which harness !
triniforever
godd dan it
Copper - Posts: 447
Posted: February 02, 2014 at 2:38 PM / IP Logged
I cant remember the model number of the Python unit off hand, but I did hook up the GREEN / WHITE wire, so I did get it right then.
I have the door lock wires working through the Dball. I will try hardwiring them. I think that will solve the problem like you said. Thanks.
