ads tb
ziggyb222
Silver - Posts: 593
Posted: September 21, 2014 at 10:24 AM / IP Logged
I have a Idata ADS TB module. I want to use it on a 08 Tundra to do locks and transponder...I think the firmware is ADS TB Tl??? Does that do everything? I cant access Idatas site right now for some reason...Thanks!!!!!
Platinum - Posts: 7,828
Posted: September 21, 2014 at 1:04 PM / IP Logged
The ADS TB flashed with the ADS TB TL firmware will only handle the transponder bypass function for that truck.
You will need an ADS AL-CA for both locks & transponder. This module will also supply door status, brake status and a Tach signal.
In the practical application, the truck is very easy to do with just the ADS TB and hard wiring the rest.
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
