DEI 530T Channel 2 delay
good vibrations
Posted: May 20, 2003 at 12:03 AM / IP Logged
I've just installed a 790 with one 530T for the front windows. My problem is that I want one button on the remote to crack the windows without delay, then if I hold it for 1.5 seconds, it should roll them down completely. As of now, I have to hold the channel two button for 1.5 seconds to get the windows to crack, and 4.5 seconds to get them to roll down. I tried channel 4 with the same results. Do I need a Bitwriter to remove the delay in channel 2?
Also, where can I pick up the hard/soft ware to program my alarm via computer?
-Matt
cpgoose
Gold - Posts: 1,098
Posted: May 20, 2003 at 8:09 AM / IP Logged
I put my 530t on a different channel just for that reason. I'm not sure how the 790 is, but on my alarm, channel 2 is for the trunk release, so it has a 2 second delay automatically. I put my 530 on channel 4, so there's no delay.
good vibrations
Posted: May 20, 2003 at 9:06 AM / IP Logged
I tried it on channel 4, but the remote was configured where I had to push two buttons simultaneously for channel 4. The delay was still present. Maybe if I reconfigure the remote to perform channel 4 with a single button push then there won't be any delay. I'll try it today, but if anyone else is familiar with this please let me know. Thanks.
cpgoose
Gold - Posts: 1,098
Posted: May 20, 2003 at 9:19 AM / IP Logged
Yea, I reprogrammed mine for "Auto Learn Single Button Arm/Disarm Configuration". #1 is lock/unlock/panic, #2 is the trunk (delay), #3 is the remote start, and #4 is the windows (no delay).
(Like on page 33 of the 790xv's install manual).
rudbwoy69camaro
Silver - Posts: 350
Posted: June 26, 2003 at 8:48 PM / IP Logged
I am going to do the same with my Matrix RS3.  I want to use channel 2.  I have the bitwriter.  Will I be able to change the setting to "no delay" for channel 2?  Please let me know.
Thanks !
auex
Platinum - Posts: 5,041
Posted: June 26, 2003 at 8:53 PM / IP Logged
Channel two cannot be adjusted or changed, channel 3/4 can be adjusted to validity(on as long as you hold the button), latched(on until you turn it off or choose of with ignition), or a 30 second latched. Check the settings for channel four of your alarm's, if they are something different then validity then change them to validity.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
rudbwoy69camaro
Silver - Posts: 350
Posted: June 26, 2003 at 10:59 PM / IP Logged
Upon arming, no matter what channel, the windows will roll up?  Just as long as it's connected to the orange ground when armed?
Spawn_X
Member - Posts: 14
Posted: June 26, 2003 at 11:05 PM / IP Logged
have you tried switching the jumpers up on the module ?
Spawn_X
Member - Posts: 14
Posted: June 26, 2003 at 11:06 PM / IP Logged
make sure you put a diode on or you might drain your battery.
rudbwoy69camaro
Silver - Posts: 350
Posted: June 27, 2003 at 8:42 AM / IP Logged
Ohh yeah I have diodes.  I bought 100 of them of ebay for $1.99.  The 1N4004, 1 amp. MANY deals on ebay !
DEI 530T Channel 2 delay -- posted image.
