Viper 4105v and Smart start
kw4tx
Member - Posts: 48
Posted: July 12, 2015 at 1:04 PM / IP Logged Link to Post Post Reply Quote kw4tx
I have a 4105v and a smart start.... I have installed a smart start in the past but am confusing myself ...probably again...
Question:
Viper shows and ESP port and a D2D port...(red) beside light jumpers
Smart Star has 3 plugs...black...brown and white...
I cant figure out whether the brown wire or white goes to D2D or the Black goes to ESP
I dont think I have to use both ESP and D2D...
So my question is Brown to D2D or white...?
And do I use Black ESP ?
Am I making myself clear?
kw4tx
Member - Posts: 48
Posted: July 12, 2015 at 1:19 PM / IP Logged Link to Post Post Reply Quote kw4tx
I also noticed my smart start doesn't have loops as stated ....It has a short grey wire and a short white wire...
are these supposed to be loops and cut if using RSR?
I have no bypass kit...
installing in a 2006 Crown Victoria P71
Posted: July 13, 2015 at 2:45 AM / IP Logged Link to Post Post Reply Quote howie ll
Use the black plug on the Viper, red and black SmartStart to same colours on Viper H1, ignore the short grey and white wires.
kw4tx
Member - Posts: 48
Posted: July 13, 2015 at 3:49 AM / IP Logged Link to Post Post Reply Quote kw4tx
SO I don't use the Red plug or the white?
I use the black on ESP port... and not the red or white...
Posted: July 13, 2015 at 4:24 AM / IP Logged Link to Post Post Reply Quote howie ll
Yes.
kw4tx
Member - Posts: 48
Posted: July 13, 2015 at 4:29 AM / IP Logged Link to Post Post Reply Quote kw4tx
Thanks Howie....
Platinum - Posts: 7,827
Posted: July 13, 2015 at 5:34 AM / IP Logged Link to Post Post Reply Quote kreg357
Additional help...
Red 4 pin port, Bitwriter/ESP2 or D2D programming
The Red 4-pin plug may be configured as a Bitwriter/ESP2 or D2D port.
The factory default is Bitwriter/ESP2 mode.
To use as D2D mode follow the below steps:
1. Make sure WHITE/ Blue activation wire is grounded.
2. Power the unit up. The system LED flashes for 5 seconds to confirm D2D mode change.
3. Remove the WHITE/ Blue wire from ground.
To change from D2D to Bitwriter/ESP2 mode:
1. Make sure the WHITE/ Blue activation w ire is grounded.
2. Power the unit up, the system LED turns on solid for 5 seconds to confirm Bitwriter ESP2 mode change.
The procedure con be repeated to toggle from one mode to the other.
Posted: July 13, 2015 at 11:04 AM / IP Logged Link to Post Post Reply Quote howie ll
Once AGAIN use RED and BLACK joined to the SAME colours on H1 don't use grey or white.
iceman1234
Posted: January 20, 2018 at 12:05 AM / IP Logged Link to Post Post Reply Quote iceman1234
Hey Howie,
I have the same problem as him.
I have the 4x03 module and I am also trying to connect Dsm350 to the module. I have solid amber light and green light on the DSM350 but the problem is I can’t smart start the car on my phone. Only lock and unlock work.   There are 4 pin white, 4 pin brown, 3 pin black plugs from DSM350
I used the white and black plug and plug them into 4x03 module on the black and red port.
Any suggestions are appreciated.
Thank you.
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
