finding tacho wire?
skyline_man
Member - Posts: 35
Posted: May 27, 2003 at 10:16 AM / IP Logged
It's relatively easy finding the tacho wire on a car with a distributor, but how do you find one on a car which uses individual coil packs?
accordh22
Member - Posts: 7
Posted: May 27, 2003 at 10:29 AM / IP Logged
You could always run it off the factory tach. I have a couple buddies who did it that way and it works fine.
cool_greg
Copper - Posts: 125
Posted: May 27, 2003 at 7:46 PM / IP Logged
or run it off one of the injectors
Greg
Mr.Swifty
Member - Posts: 37
Posted: May 28, 2003 at 2:26 AM / IP Logged
Generally I find that on each individual coil pack there is a common colored wire....pick the other one
Glynn
Member - Posts: 36
Posted: May 28, 2003 at 3:08 AM / IP Logged
usual on the engine dianogsic (or however its spelt!) has a tach wire. Can be found under the dash or engine bay depending on car. Skylines are in the car-its where a technican will plug their computer into
Monday, December 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
