Viper 5906v
billybob2012
Posted: January 03, 2016 at 12:50 PM / IP Logged Link to Post Post Reply Quote billybob2012
I recently had the Viper 5906v installed in my Sierra and noticed that if the truck is running that the Viper remotes will not lock or unlock the truck only the factory remote will. Is there any way to change this or does the having the ignition on disable the remotes functions?
dairyboy3
Copper - Posts: 52
Posted: January 04, 2016 at 12:18 PM / IP Logged Link to Post Post Reply Quote dairyboy3
What year is it? Was a module used? The Viper remotes should definitely be unlocking the truck while it was running. Are you getting confirmation chirps from the siren when you push lock or unlock from the viper remote?
billybob2012
Posted: January 04, 2016 at 4:41 PM / IP Logged Link to Post Post Reply Quote billybob2012
It's a 2004 and yes a module was used. I found that you can put it in pit stop mode by activating remote start while running and getting out and locking it. It will not lock or unlock while running without doing this and yes it does chirp when using the remote
