2009 Highlander with Prestige APS57E & FLCAN
redknights
Member - Posts: 13
Posted: March 05, 2016 at 7:41 PM / IP Logged Link to Post Post Reply Quote redknights
I'm helping a friend install his remote start in a 09 Highlander STD key with no factory alarm. He got a Prestige APS57E and FLCAN. I'm looking at the Type 1 install guide on the FLCAN and will be using the DATA Mode cable. I'm mapping out the connections and need help on a few cables. From the FLCAN to R/S, do I need to run the E-Brake, Ignition, and Trunk status to each other? Do the FLCAN also handles the door lock/unlock and hood pin? Please verify my connections below. Thank You!!!
Prestige APS57E
6-PIN Power/Start Harness
1 BLUE (+) Ignition 1 >>> ignition switch, white 8 pin plug, pin 6:(+) BLACK
2 RED / WHITE (+) Battery 1 12V >>> ignition switch, white 8 pin plug, pin 5:(+) WHITE/ BLACK
3 GREEN     (+) Ignition 2 >>> ignition switch, white 8 pin plug, pin 1:(+) LT BLUE
4 PURPLE (+) Accessory >>> ignition switch, white 8 pin plug, pin 2:(+) GRAY
5 RED (+) Battery 2 - 12V >>> ignition switch, white 8 pin plug, pin 5:(+) WHITE/ BLACK
6 YELLOW Starter Output     >>> ignition switch, white 8 pin plug, pin 7:(+) YELLOW
Door Lock, 3-PIN Connector (Need to connect or FLCAN handles them???)
1 RED (-) Door Lock Output >>> D2D or driver kick, black 18 pin plug, pin 8:ORANGE
2 GREEN     (-) Door Unlock Output >>> D2D or driver kick, black 18 pin plug, pin 9:GREEN
4-PIN 2nd Main Harness
1 BLACK     Chassis Ground >>> Ground Chassis
2 WHITE/ RED Parking Light Input     >>> NA
3 YELLOW/BLACK     To Controlling Alarm's Ignition Input >>> FLCAN:PINK???
4 WHITE     (-) Parking Light Output >>> headlight switch, white 20 pin plug, pin 18:LT BLUE
14-PIN Main Harness
1 GREEN/ ORANGE Tachometer Input D2D
2 GREEN/ YELLOW Glow Plug Input     NA
3 DK BLUE (-) Channel 3 Trunk Release Output NA
4 BROWN / BLACK (+) Inhibit/Shutdown To Brake Switch >> D2D or dash fuse box, white 12 pin plug (1P), pin 3:(+) BLUE
5 BROWN (+) Inhibit/Shutdown To Brake Switch D2D
6 GRAY (-) Inhibit Neutral Start Switch D2D???
7 NA
8 BLACK / YELLOW (-) Pulse During Crank Output NA
9 BLACK/ RED (-) Pulse After Shut Down Output NA
10 BLACK/ BLUE (-) Pulse Before Start Output NA
11 BLACK/ LT GREEN (-) After Start Output NA
12 LT BLUE (-) Ground While Running Output >>> D2D
13 GRAY/BLACK (-) Inhibit/Shutdown To Hood Switch >>> D2D
14 BLACK/ WHITE (-) Horn Output >>> dash fuse box, white 16 pin plug (1D), pin 11:(-) GRAY
FLCAN Type1 Install
TXCT GRAY/RED >> Immobilizer PIN 5-LT BLUE
CODE GREEN/ RED >> Immobilizer PIN 4-RED
Parking Light >> R/S Output:     headlight switch, white 20 pin plug, pin 18:LT BLUE
Can High BROWN / RED >> ODBII PIN 6-BLUE
Can Low     BROWN / YELLOW >> ODBII PIN 14-WHITE
FLCAN to Remote Start
GREEN (-) E-Brake Status Output NA
PINK (+) Ignition Input     >> FLCAN 4 PIN Harness:YELLOW/BLACK???
YELLOW/RED (-) Trunk Status Output NA
triniforever
Copper - Posts: 323
Posted: March 05, 2016 at 8:50 PM / IP Logged Link to Post Post Reply Quote triniforever
If this is a one way system you will also need to connect some of the red dotted lines on the FLCAN and unless the truck is a manual you dont need the E-Brake output and since you have a negative park light on this vehicle connect the RED / White wire to ground ,lock and unlock needs to be connected to the FLCAN , the Yellow/Black wire on the remote start is not needed in this case, the Pink ignition wire from the FLCAN can go to the vehicle Black ignition wire and that unit is not an alarm so trunk status is not needed ,however the unit has a hood status output (Grey/Black) which can be connected to the Yellow wire from the FLCAN ,the Grey wire from the unit goes to ground on the vehicle .
triniforever
triniforever
Copper - Posts: 323
Posted: March 05, 2016 at 8:58 PM / IP Logged Link to Post Post Reply Quote triniforever
Also the FLCAN gives you a Tach output so connect the GREEN/ Orange wire from the unit to the PURPLE / White wire on the FLCAN ,the rest of your connections look ok except for the BROWN / Black wire from the unit needs to be connected to the Orange wire on the FLCAN and the Brown wire from the unit can also be connected to the Orange wire or you can leave it not connected im not sure maybe someone else on here can give you some more information on that wire .
triniforever
redknights
Member - Posts: 13
Posted: March 05, 2016 at 10:23 PM / IP Logged Link to Post Post Reply Quote redknights
Thanks triniforever, I forgot that this is a one way R/S so I need the wires going to the FLCAN instead of the Data Mode. What about the other required connections (12V, Ground, and Ground When Running) from the R/S to FLCAN? Can I use the (1) Black in 4PIN harness to FLCAN:Black, (12) in 14PIN harness to FLCAN:BLUE/WHITE, and 12V form R/S. Here are the updates connections and NC is no connection.
1 RED (-) Door Lock Output >>> FLCAN Lock:GREEN/ BLACK
2 GREEN (-) Door Unlock Output >>> FLCAN Unlock:BLUE/BLACK
1 BLACK Chassis Ground >>> To FLCAN Ground:BLACK ?????
2 WHITE/ RED Parking Light Input >>> Ground Chassis
3 YELLOW/BLACK To Controlling Alarm's Ignition Input >>> NC
14-PIN Main Harness
1 GREEN/ ORANGE Tachometer Input >>> FLCAN Tach:PURPLE / WHITE
2 GREEN/ YELLOW Glow Plug Input NC
3 DK BLUE (-) Channel 3 Trunk Release Output NC
4 BROWN / BLACK (+) Inhibit/Shutdown To Brake Switch >>> FLCAN (+) Brake Output:ORANGE
5 BROWN (+) Inhibit/Shutdown To Brake Switch ?????
6 GRAY (-) Inhibit Neutral Start Switch >>> Ground Chassis
7 NA
8 BLACK / YELLOW (-) Pulse During Crank Output NC
9 BLACK/ RED (-) Pulse After Shut Down Output NC
10 BLACK/ BLUE (-) Pulse Before Start Output NC
11 BLACK/ LT GREEN (-) After Start Output NC
12 LT BLUE (-) Ground While Running Output >>> FLCAN Ground Input: BLUE/WHITE ?????
13 GRAY/BLACK (-) Inhibit/Shutdown To Hood Switch >>> FLCAN Hood Status:YELLOW
GREEN (-) E-Brake Status Output NC
PINK (+) Ignition Input >> ignition switch, white 8 pin plug, pin 6:(+) BLACK
YELLOW/RED (-) Trunk Status Output NC
triniforever
Copper - Posts: 323
Posted: March 06, 2016 at 7:38 AM / IP Logged Link to Post Post Reply Quote triniforever
In what mode did you flash the FLCAN, Data or Hardwire ? Also you can connect the R/S Dark/blue trunk release wire to the FLCAN RED / White wire. The FLCAN Power and Ground wires can go to any 12v and ground either from the remote start or the vehicle , the GWR from the FLCAN can be connected to the Light/Blue wire on the R/S unit .
triniforever
redknights
Member - Posts: 13
Posted: March 06, 2016 at 9:33 AM / IP Logged Link to Post Post Reply Quote redknights
Thanks again triniforever!!! I didn't do anything yet, the installation will be next week. I'm just mapping everything out to get it ready for the install. Should I flash it DL-TL1 with Data 1-Way?
triniforever
Copper - Posts: 323
Posted: March 06, 2016 at 10:39 AM / IP Logged Link to Post Post Reply Quote triniforever
Actually do hardwire since that what it is wired for and good luck!
triniforever
redknights
Member - Posts: 13
Posted: March 13, 2016 at 8:22 PM / IP Logged Link to Post Post Reply Quote redknights
Had a chat with Kreg and he helped me out tremendously. His detailed install process were amazing. This is his recommendations.
This is a bit complicated, so hopefully I can explain it properly.
The APS57E is a nice unit. From the factory is comes set to DBI D2D mode. That is exactly want the FLCAN needs, so set the FLCAN to Installation Mode = DATA ( one blink flash pattern ) and lock it in. Of course the FLCAN must be flashed with the DL TL1 firmware for your Highlander. The FLCAN and APS57E can communicate in full 2 way data mode via the D2D cable, so all the Orange dash lines are valid.
1 RED (-) Door Lock Output >>> D2D harness
2 GREEN (-) Door Unlock Output >>>   D2D harness
1 BLACK Chassis Ground >>> To Highlander frame / chassis ground
2 WHITE/ RED Parking Light Input >>> Ground Chassis ( join with Pin 1 above )
14-PIN Main Harness
1 GREEN/ ORANGE Tachometer Input >>>   D2D harness
3 DK BLUE (-) Channel 3 Trunk Release Output      D2D harness   ( Tailgate window release )
4 BROWN / BLACK (+) Inhibit/Shutdown To Brake Switch >>>   D2D harness
5 BROWN (+) Inhibit/Shutdown >>> not used
6 GRAY (-) Inhibit Neutral Start Switch >>> not used
7 NA
8 BLACK / YELLOW (-) Pulse During Crank Output   >>> to relay for ACC1 circuit
12 LT BLUE (-) Ground While Running Output >>>   D2D harness
13 GRAY/BLACK (-) Inhibit/Shutdown To Hood Switch >>> to kit supplies hood pin switch
Wire Side View Of Connector
1 Blue (Ign 1)   Black      Ignition1 * also gets FLCAN Pink wire
2 RED / White (+ 12VDC Relays Ign 1 & Ign 2) WHITE/ Black +12V
3 Green (Ign 2)Light Blue thin      Ignition2
4 Purple (Accessory) ** Red thin Starter2
5 Red (+ 12VDC Relays ACC & Start)        WHITE/ Black +12V
6 Yellow (Starter) Yellow     Starter1
The problem is that the Highlander needs 2 Ignition, 2 Starter and one Accessory outputs from the APS57E. As shown above the APS57E is not able to power the Accesory1 circuit during a remote start. To accomplish this you will need a 30/40 Amp SPDT relay wired up like this :
Relay Pin 85 to BLACK / YELLOW ( Pulse During Crank Output) **APS57E programming required
Relay Pins 86 and 87 to +12V constant through 10 Amp fuse
Relay Pin 30 to Light Blue ( thin ) Ignition2
There will be some programming you have to do on the APS57E. Bank 3, 5th Feature should be set to DBI Tach. For the Accesory1 circuit ( ** ), change Bank 3, 20th Feature to "Same as ACCY". To change the APS57E wire from ACCY to Starter2, change Bank 3, 9th Feature to "Same as Starter".
As you can see, to get all the Highlander's ignition circuits powered properly we have :
APS57E to Highlander
IGN1 going to IGN1
IGN2 going to IGN2
Starter1 going to Starter1
We changed the ACC output over to a Starter output and connected that to Starter2. We added a relay controlled by the BLACK / YELLOW wire to power the ACC1 circuit.
Confusing but the only way to do it.
As for the Hood Pin, if you don't have the Factory Alarm system, your Highlander probably doesn't have a Hood Pin and the FLCAN will not be able to supply that signal to the APS57E. This is something you can test for after the install. If opening the hood while remote started does not shutdown the engine, install the APS57E kit supplied hood pin and hard wire that input signal and connect the FLCAN ORANGE / Black wire to chassis ground.
Going with D2D, there is no need to hardwire either Brown or BROWN / Black (+) Inhibit Input. The FLCAN will supply the
Foot Brake signal via D2D, just like it does for Lock, Unlock, Hatch release and Tach.
Kreg
The RS did had issues picking up the tack during the learning process through DBI. I hardwired it from RS.
1.GREEN/ ORANGE Tachometer Input >>> ODBII Lt Blue and changed Bank 3, 5th feature to Tach.
