2016 Camry PTS light issue
dts828
Member - Posts: 7
Posted: March 26, 2016 at 11:20 AM / IP Logged Link to Post Post Reply Quote dts828
Installed standalone remote start using idatalink ads_alca module, works fine but parking lights are not on when car is remote started, connected to pin 30 black wire/ecu white 30pin plug.   After checking found they work if headlight switch is in drl/off position but they don't work if the switch is in the auto position.   Has anyone come across this, any where else to hook the negative output for parking lights that will work when the light switch is in auto position.
brownsfan1
Copper - Posts: 65
Posted: March 26, 2016 at 7:34 PM / IP Logged Link to Post Post Reply Quote brownsfan1
It won't work if you use negative park lights. You need to use the positive park lights to work when in the auto position. Pink wire in a white 36 pin plug at the dash fuse box.
brownsfan1
Copper - Posts: 65
dts828
Member - Posts: 7
Posted: March 29, 2016 at 8:12 PM / IP Logged Link to Post Post Reply Quote dts828
Thanks for the solution.
Tuesday, July 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
