Tuesday, March 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Hey guys, ran into a snag here, could use some help. This is the Avital 5303 and DBall2 for a 2006 Pontiac G6. In the pic you'll see a purple circle that shows what looks like a connection between dball (+) ignition input and starters (+) ignition output and then out to the ignition switch. Considering all broken blue lines are not required, how do I read that connection? Also the dball2 pic shows the starters ignition as an "output" and the starter pic shows the ignition as an "input". I'm hoping someone can sort this out for me, thanks.
