Tahoe 2000 auto start installation
hisan0307
Posted: November 03, 2016 at 1:25 PM / IP Logged Link to Post Post Reply Quote hisan0307
Hey guys I'm new in this forum and I hope you can help me. I'm planning to install an auto start and security alarm system in my Tahoe 2000. I bought a viper 5706v 2-way alarm and I want to know if I need any additional parts in order to work fine. also, I have been searching information about the installation process and there are different way to install. I will appreciated your help in all the advise or instruction you can give me for complete this installation. Thanks again.
dairyboy3
Copper - Posts: 52
Posted: November 03, 2016 at 3:43 PM / IP Logged Link to Post Post Reply Quote dairyboy3
Use a DBALL 2. It will take care of a few features such as door locks, door triggers, tach, hatch release, and will also take care of the passlock 2 bypass.
Platinum - Posts: 7,827
Posted: November 03, 2016 at 3:58 PM / IP Logged Link to Post Post Reply Quote kreg357
If you use the DB-ALL2 suggested above, get if flashed with the proper firmware by the seller prior to shipment. If you want to do it slightly differently...
You will need a few more items to complete the install.
Your truck has the Passlock2 engine immobilizer system and needs to be bypassed during a remote start. Due to the
extreme cold weather in Alaska, I would recommend a data style bypass module rather than a resistor based unit. My
favorite is an iDatalink ADS TBSL PL. Another good choice is the Fortin INT-SL or INT-SL+. Either module will work
with your Viper in W2W mode.
Most of the necessary wires are found at the BCM just under the steering column. This truck has Type A Locks and
needs a Directed 451M Door Lock Module to change the Vipers (-) polarity lock outputs to the (+) 12V signal needed.
Here is a link to a Pictorial on the 99 - 02 Silverado : https://www.the12volt.com/installbay/forum_posts.asp?tid=135786
This vehicle is very similar to yours. The only wires not shown are the Door Pins needed for alarm system access
monitoring.
hisan0307
Posted: November 03, 2016 at 4:20 PM / IP Logged Link to Post Post Reply Quote hisan0307
Thanks for the response guys first. This probably will sound weird but my Tahoe Doesn't came with the BCM ( apparently by Chevrolet is located in the central consul) but by the Vin number doesn't have one. so I'm stuck in that part because I don't know where connect the cables going to the BCM.
kreg357m, I saw those post about the Silverado before but those connection are different in my Tahoe. Thanks again guys.
geepherder
Platinum - Posts: 3,668
Posted: November 03, 2016 at 11:13 PM / IP Logged Link to Post Post Reply Quote geepherder
https://www.the12volt.com/installbay/alarmdetail/575.html
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
