Help with an Acura 3.0cl security system
SSteve
Member - Posts: 20
Posted: May 27, 2003 at 7:55 PM / IP Logged
I am trying to roll my windows up (window module already installed) using the existing factory alarm 1997 Acura CL 3.0
Steve
SSteve
Member - Posts: 20
Posted: May 30, 2003 at 4:11 PM / IP Logged
Thank you!, I really need somebody to give me information about my car factory alarm:
What I want to do is to install an aftermarket remote starter, power windows module, (to roll the windows up and down) and some other accessories, but I need to know the function of the wires from my factory alarm.  i.e, I can't find the ground when armed output wire, do you know the color?
Any help will be apreciated.Help with an Acura 3.0cl security system -- posted image.
Steve
Platinum - Posts: 12,488
Posted: May 30, 2003 at 4:31 PM / IP Logged
Hey Steve, the OEM system will not have a constant ground when armed wire. Why do you need this wire any way ? What year CL do you need information for ?
uiskibum
Posted: May 30, 2003 at 4:41 PM / IP Logged
I've been considering doing the same thing.  Let me know if you get it working.
djfearny2
Silver - Posts: 810
Posted: May 30, 2003 at 5:36 PM / IP Logged
ok there is no ground when armed output wire on factory systems., why cause there is no starter kill thats what the ground when armed wire is mainly for,. 2 the car most likely has a chipped key so that is it's starter kill. get it. you can however use a timer relay on the lock motor wire of the car to flip from possitive to negative so that when you arm the car and lock the doors it will roll the windows up. negative out comes. if the car has a system in it that locks the doors when the car has been driving a little while or put into drive this will cause the windows to go up. . now the factory alarm does not have features on found on after market alarms such as more channels. and things like starter kill. ground when armed wire and does not have a shock sensor the only thing it has is a hood pin, trunk pin, and door pins as sensors and some newer cars have internal proximity sensors or movement sensors. but you dont your best bet is to get a complete alarm remote start. after market package. you will get starter kill., shock sensor. most alarms have to channel useable outputs. substancial range increase. your best bet.
Jon
Installer/Help Technician
---coral springs florida---
SSteve
Member - Posts: 20
Posted: May 30, 2003 at 7:56 PM / IP Logged
Ok, I though it was going to be easier to do this,  I better install a whole new alarm with the remote starter and all that stuff... but i'm happy you guys reply so next time I have a more realistic question, i know you will help people like me, (beginer)  only 2 years installing... Thank You much!
Steve
Posted: May 30, 2003 at 8:00 PM / IP Logged
No problemo Steve...... even the pro's need help on this forum so don't feel bad about posting questions. The only stupid question is the one that is never asked Help with an Acura 3.0cl security system -- posted image.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
