2004 Dodge Ram 2500 5.7l Hemi remote start instl
stormyj
Member - Posts: 12
Posted: December 27, 2016 at 4:38 PM / IP Logged Link to Post Post Reply Quote stormyj
Hi all,
Attempting an install on above vehicle. excel file has connections from the autopage rs-730a and the vehicle and where I think they should go. There will be some diodes on door switches and a few resistors I believe. If any pros can take a look and see if there is anything I missed or something i need to add, I would greatly appreciate it. I will be checking voltage as I go.
thanks
Jim
Excel file
http://www.filehosting.org/file/details/629157/ram2500connections.xlsx
stormyj
Member - Posts: 12
Posted: December 27, 2016 at 4:45 PM / IP Logged Link to Post Post Reply Quote stormyj
Also for the door locks.
Door locks are a 1-wire system, the lock requires a Neg thru a 820 ohm resistor and unlock requres a Neg thru a 330 ohm resistor. Some units might need 2 ea 775 relays
Platinum - Posts: 7,828
Posted: December 28, 2016 at 8:47 PM / IP Logged Link to Post Post Reply Quote kreg357
Get a Direct 451M door lock module. They cost $9 and include an assortment of resistors. Makes life easy.
Could you post the Excel file? I don't mind looking it over but really don't want to give them my email address...
stormyj
Member - Posts: 12
Posted: December 31, 2016 at 11:55 AM / IP Logged Link to Post Post Reply Quote stormyj
I dont think I can upload a file. Not a silver or gold member.
Posted: December 31, 2016 at 12:56 PM / IP Logged Link to Post Post Reply Quote kreg357
Cut and past might work. Even manually typing it in, if you would like the Forum members to review it.
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
