Locks Not Working, 05 Toyota Tundra Double Cab Limited
djstraub
Posted: January 14, 2019 at 9:47 AM / IP Logged Link to Post Post Reply Quote djstraub
Before anyone suggests its the actuators I already changed one out and it didn't fix it.
I attempted to install a remote start system. When I went to connect to the unlock/lock wires with 5 pin relays something went wrong. I smelt a burning smell. (I uninstalled the 5 pin relays)The doors will not unlock/lock with the factory key fob or from inside the vehicle with the driver or passenger lock/unlock buttons. I have check every fuse in the vehicle and there all good.
Based on my research It could be either the receiver door control or possibly a relay. Anyone else ever made this mistake ?
Any help would be great.
Thanks!
djs
2001eclipse
Member - Posts: 29
Posted: January 16, 2019 at 4:19 AM / IP Logged Link to Post Post Reply Quote 2001eclipse
So the truck came with power door locks already Im assuming, but I dont understand why you would still need relays for the door locks?
What remote start system did you install?
If the system you installed had a (-) output for lock/unlock wires, you could just wire them directly to the lock/unlock wires in the truck. I cant remember off the top of my head but it should be behind the kick panel... but I understand that your locks arent working anymore... Where and what wires did you connect the wires from your relays to?
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
