Why Did The Shop Do This? 2001 Tahoe, Viper 5706, DB3
mr.martinez562
Member - Posts: 19
Posted: January 27, 2019 at 2:19 PM / IP Logged Link to Post Post Reply Quote mr.martinez562
2001 chevy tahoe 5706 viper Db3 bypass module shop took over installation since I didnt get any feedback on my original thread regarding the wiring schematic I had laid out hoping to get sum feed back after this pic of what the shop did to my tahoe and get to fix it. Quick run down they eliminated the Db3 added 3 relays use tape and butchered my wiring after I had solder, shrink wrapped, and tesa tape my harness.
Mr.562
mr.martinez562
Member - Posts: 19
Posted: February 17, 2019 at 12:46 PM / IP Logged Link to Post Post Reply Quote mr.martinez562
Why Did The Shop Do This? 2001 Tahoe, Viper 5706, DB3 -- posted image.
Mr.562
mr.martinez562
Member - Posts: 19
Posted: February 17, 2019 at 2:24 PM / IP Logged Link to Post Post Reply Quote mr.martinez562
I believe that this write up by kreg357 is the only thing close to my tahoe viper and module except that I run negative MH 5 connection. 2002 Silverado with Viper 5806 and DB-ALL2 flashed with 4.02 GM5 Ver 3.12.106a firmware.
Assumptions : Gasoline engine, factory door locks, going with D2D between Viper & DB-ALL2.
There is no need for the 451M door lock module, the DB-ALL2 will handle the locks and alarm via it's connection to the J1850
Data wire at the OBD2 connector.
          Pin Color          Description     Destination
MH   1 Red      (+)12VDC Constant Input      Red (+) @ ignition harness
MH   2 Black             (-) Chassis Ground      Chassis Ground
MH   3 Brown            (+) Siren Output       Viper siren
MH   4 WHITE/ Brown     Parking light isolation        Not Used
MH   5 White             Parking light output BCM Gray Connector, Brown wire, pin 6 (+)     * Set jumper to (+)
MH   6 Orange          (-)500mA Ground when armed        Not used
DL   1 Blue (-)500mA Unlock output            Not used - handled via D2D
DL   2 EMPTY
DL   3 Green (-)500mA Lock output Not used - handled via D2D
RS   1 NC
RS   2 RED / Black   (+) Fused 12V acc/start input          RED / White (+) @ ignition harness
RS   3 Pink/Black (+) Flex relay input 87a key side     Not used
RS   4 Pink/White (+) Ignition 2/flex relay output        White (+) @ ignition harness
RS   5 Red   (+) Fused 12V Ignition 1 Input      Red (+) @ ignition harness
RS   6 Green   (+) Starter Input (key side)       Yellow (+) @ ignition harness     cut wire
RS   7 Violet   (+)Start output (car side)           Yellow (+) @ ignition harness     cut wire
RS   8 Orange       (+) Accessory output          Orange (+) @ ignition harness
RS   9 RED / White (+) Fused 12V Ignition 2     RED / White (+) @ ignition harness
RS 10 Pink (+) Ignition 1 Input/output Pink (+) @ ignition harness
AST   1 Pink/White   (-) 200mA Ignition 2/flex Output           not used
AST   2 Blue/White   (-) 200mA 2nd Status/rear defog output          not used
AST   3 RED / White    (-) 200mA trunk release output not used
AST   4 BLACK / YELLOW   (-) 200mA dome light output              not used
AST   5 Dark Blue    (-) 200mA status output           Not used - handled via D2D
AST   6 WHITE/ Black   (-) 200mA AUX 3 output        not used
AST   7 WHITE/ Violet   (-) 200mA AUX 1 output        not used
AST   8 ORANGE / Black   (-) 200mA AUX 4 output      not used
AST   9 Gray (-) Hood pin input (NC or NO)             to kit supplied hood pin
AST   10 Blue (-) trunk pin/instant trigger input (NC or NO)      not used
AST   11 WHITE/ Blue   Activation Input        not used
AST   12 Violet/White   Tachometer input Not used - handled via D2D
AST   13 BLACK/ White   (-) neutral safety/parking brake input            Not used - handled via D2D ( E-Brake ? )
AST   14 GREEN/ Black   (-) 200mA Factory alarm disarm output       Not used - handled via D2D
AST   15 Green (-) Door input        Not used - handled via D2D
AST   16 BROWN / Black   (-) 200mA horn honk output optional ( already have Viper siren )
AST   17 Pink (-) 200mA Ignition 1 output     not used
AST   18 Violet (+) Door input           not used
AST   19 Violet/Black   (-) 200mA AUX 2 output      not used
AST   20 Brown (+) Brake shutdown input    White (+) @ brake pedal switch
AST   21 Violet / YELLOW   (-) 200mA starter output    not used
AST   22 Gray/Black   (-) Diesel wait to start input not used
AST   23 Orange (-) 200mA accessory output       to extra relay Pin 85 ( for Brown ACC2 wire )
AST   24 GREEN / WHITE   (-) 200mA factory alarm arm output Not used - handled via D2D
DB-ALL2
D2D harness to Viper
Blue 14 Pin Plug
Pin 2 Violet / YELLOW to OBD2 Pin 2 Violet
Red 12 Pin Plug
Pin 1 BLACK/ White to Tan (-) @ BCM, purple plug, pin B4
Pins 8 & 9 to Yellow Passlock2 wire at steering column harness
Black 10 Pin Plug
Pin 8 Violet to Viper     RS   Pin 7 thick Violet (+) Start output
Pin 9 Pink to Viper       RS   Pin 10 thick Pink (+) Ignition 1 Input/output
Extra relay ( 8617 ) for ACC2 :
Pin 85 to Viper    AST   Pin 23 Orange (-) 200mA accessory output
Pin 86 and 87 to Red (+) @ ignition harness through 25 amp fuse
Pin 30 to Brown ACC2 @ ignition harness
Pin 87a not used
The DB-ALL2 must be flashed with the above specified firmware. Here is a link to the install guide :
http://www.xpresskit.com/DocumentDownload.aspx?documentid=9294&productid=553&firmwareid=6501
Follow the Type 4 diagram / instructions. You will need an XKLoader2 cable to flash the DB-ALL2.
There will be some programming changes necessary for the Viper. Things like Transmission Type, Engine Checking,
etc.
Mr.562
Platinum - Posts: 7,828
Posted: February 17, 2019 at 5:42 PM / IP Logged Link to Post Post Reply Quote kreg357
OMG. It's work like that that gives the 12 Volt industry a bad reputation.
First question. Does it work?
( the pre-question is why did you bring it to someone? I'm sorry you didn't get a reply from you original post.
   I don't use Directed products and after their recent purge, don't answer too many questions due to lack of
   current knowledge of their products. )
Even if your Tahoe has a Factory Alarm system, you really don't need a full featured bypass module like the
DB-ALLx series. Sure, they make things easier but a simple Passlock2 bypass module is all you need. And that
appears to be what the install shop did. They used the old school "Relay and Resistor" method to bypass the
Passlock2 during R/S. The other two relays are used convert the Vipers (-) Door Lock outputs to a (+) signal
that the Tahoe needs, one for Lock and the other for Unlock.
Don't know what to tell you. I would be very hesitant to bring it back to that shop. If it didn't work
properly, I would ask for a refund. If it works properly, I'd be tempted to clean up the install, getting
rid of the crimp connectors, soldering and heat shrinking everything, etc, making it neat and call it a day.
Remember that the removed curved metal plate has some unfinished edges on it, so make sure the harnesses are
well protected in that area.
mr.martinez562
Member - Posts: 19
Posted: February 17, 2019 at 5:58 PM / IP Logged Link to Post Post Reply Quote mr.martinez562
I already had wired up using solder, heat shrink, and Tesa tape all that needed was the programming according to the flashes from the module it wasnt communicating and after reading that this modules dont take on the first try I assumed it needed to be reflashed with the proper software called around only shop that would reprogram it for me.
It locks and unlocks but it doesn't start the tahoe, cranks but doesnt engage. Relays have no resistors from what I see and no they was not payed since they decided to do that work without contacting me and advance they butchered wires that were solder and they left wires without no protection (bare wires).
Mr.562
Posted: February 17, 2019 at 6:01 PM / IP Logged Link to Post Post Reply Quote kreg357
Check the instrument cluster to see if the "Security" light is on during R/S cranking.
That would indicate that the Passlock2 is not being bypassed and preventing fuel from
getting to the engine.
Posted: February 17, 2019 at 6:18 PM / IP Logged Link to Post Post Reply Quote kreg357
Can't see the wires all that well, but it looks like the Yellow Passlock2 wire has something
connected to it. Guess that the 3rd relay was for the Brown ACC2 wire. If that's the case,
you will need a bypass module for the Passlock2 being as the DB-ALL3 is removed. If you
trust the Viper alarm system to protect the Tahoe, you could do a permanent bypass on the
Passlock2 or get a Fortin Passlock SL2 or a Directed 556 LW bypass module.
mr.martinez562
Member - Posts: 19
Posted: February 17, 2019 at 6:19 PM / IP Logged Link to Post Post Reply Quote mr.martinez562
When I use the key it starts up fine when I use the rs it just cranks three times and then everything and the cluster goes dark (no lights).
Mr.562
Posted: February 17, 2019 at 6:29 PM / IP Logged Link to Post Post Reply Quote kreg357
Any "Security" light on the instrument cluster during R/S crank attempts?
mr.martinez562
Member - Posts: 19
Posted: February 17, 2019 at 6:31 PM / IP Logged Link to Post Post Reply Quote mr.martinez562
Seems that they connected the orange from Rs to my brown ignition harness the black/white rap off to my passlock and no it doesnt show security it does show my battery when I start using the Rs.
Mr.562
Page of 4
