2018 Toyota Avalon PTS Remote Start Install
mcgrathe
Member - Posts: 15
Posted: September 11, 2019 at 6:22 PM / IP Logged Link to Post Post Reply Quote mcgrathe
Hello all. Would anyone have the diagram to install an iDatalink ADS-ALCA and viper 4606V D2D into a 2018 smart key Push Button Start Toyota Avalon. the factory remote range is horrible so i want to use my 4606V and program the 2 way remote i have.
Thank you
Eric M
cpalmer
Copper - Posts: 115
Posted: September 11, 2019 at 6:49 PM / IP Logged Link to Post Post Reply Quote cpalmer
Should be able to find what you need on the iDatalink website. Do you have an XL202 from DEI to go with that?
mcgrathe
Member - Posts: 15
Posted: September 11, 2019 at 7:20 PM / IP Logged Link to Post Post Reply Quote mcgrathe
Hmm. No not familiar with the XL202. In my 15 pilot I did it all with a 4606V and programmed a 7756v lcd remote to it and the ALCA d2d. Can I use just an Alca and an xl202 with 2 way lcd remote and eliminate 4606v alarm?
Eric M
mgoetz74
Silver - Posts: 424
Posted: September 12, 2019 at 1:20 PM / IP Logged Link to Post Post Reply Quote mgoetz74
http://images.idatalink.com/corporate/Content/Manuals/DL-TL6/ADS-AL(DL)-TL6-EN_20190726.pdf
why not just use the alca and do RSR and add on a 2 way compsutar remote pack? The viper remote start is over kill considering there is no take over for Toyotas so when you open the door the RS will shut down and you have to restart the car. $100 for alca and $100 for compustar remote pack (prime r3 or prime g15). Would do the prime r3 since you really only need remote start since the car unlock when you walk up to the car with the prox key
RSR-
http://images.idatalink.com/corporate/Content/Manuals/RS-TL6/OEM-AL(RS)-TL6-[ADS-ALCA]-EN_20190726.pdf
mcgrathe
Member - Posts: 15
Posted: September 12, 2019 at 4:21 PM / IP Logged Link to Post Post Reply Quote mcgrathe
I already have all the viper stuff but yes what you suggested would work to. I’m curious if an XL202 will communicate with the ALCA? I Also have a Directed DB3 that I can get flashed. Would that most likely be the best option used with an XL202?
Thank you
Eric M
silvercivicsir
Copper - Posts: 416
Posted: September 15, 2019 at 4:53 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
xl202 will work with a Dball2 or Dball 3
