2016 Honda Civic Touring, DEI 535Ts Installed Successfully
tonton81
Member - Posts: 9
Posted: April 07, 2020 at 6:20 PM / IP Logged Link to Post Post Reply Quote tonton81
If anyone attempts to install 535T in newer hondas, I've successfully done it. The back door motors require a mod, and the window switches for front require programming (you can do this yourself), and now i have one-touch available in back windows. I added the 535T to front as well but left one-touch on 535T disabled, using OEM instead. I have it integrated on CANbus via a MCU, which when I walk away (stock walk away keyless), all windows roll up. The bonus of having the 535Ts is while the GWA wire is grounded, I can now disable the factory rolldown from keyfob and stop the accidental rolldowns because the window switches are ignored! :)
