please help with lynx 2000
CruisinS&S
Copper - Posts: 225
Posted: June 08, 2003 at 9:18 PM / IP Logged
Hi I installed a lynx 2000 in a 96 eclipse the problem is that when the car is started with the key it remains running and if brake is depressed nothing happens! The smaller gauge brown wire is used for the brake signal and is testing like it should. The yellow wire is hooked to ign 1.
PLEASE HELP Thanks
Cruisin Security And Sounds
Platinum - Posts: 12,488
Posted: June 08, 2003 at 9:28 PM / IP Logged
Do you have the system in MANUAL mode ?
CruisinS&S
Copper - Posts: 225
Posted: June 08, 2003 at 10:25 PM / IP Logged
no the system is in auto mode and the tach was learned
Posted: June 09, 2003 at 11:59 AM / IP Logged
From what you have described above, the brake should not shut the car down if you started it with the key. Only with the remote starter does the brake input shut down the engine.
CruisinS&S
Copper - Posts: 225
Posted: June 09, 2003 at 6:46 PM / IP Logged
brake does not shut the car off when remote started!
Posted: June 09, 2003 at 9:41 PM / IP Logged
Then there is something wrong with the brake input on the CPU. Bring it back to the dealer and get the CPU replaced or repaired. Sunny should be able to look after you on this for warranty at PME.
CruisinS&S
Copper - Posts: 225
Posted: June 10, 2003 at 7:29 PM / IP Logged
thanks Jeff that's what we have done, I saw in one of your posts that you highly recommend these units. Are they that reliable? Do they have the dependability of a DEI or Prestige unit?
Posted: June 11, 2003 at 10:53 AM / IP Logged
I have not had any problem units since I started installing them in March. We have gone through about 30 units so far with 0 problem or returns from any customers.
