2002 Dodge Ram 3500, Disarm Factory Security System
chainsaw96
Posted: November 07, 2021 at 11:14 AM / IP Logged Link to Post Post Reply Quote chainsaw96
Hello, I m having trouble with my 2002 Dodge Ram 3500 diesel. Twice it has failed to disarm the security system after the doors are locked. This truck has automatic locks. Each time it wasn’t able to be fixed by the dealer. I was able to fix it by replacing the body control module. These are obsolete. Junkyard is the only place I can find them. I read where you can put a negative pulse through a 1500 ohm resistor on the geeen wire with an orange stripe, located on the drivers side kick panel. I have located the wire but am unsure how to do this. Can this be done with a bolt/ohm meter?
Platinum - Posts: 13,725
Posted: November 07, 2021 at 4:46 PM / IP Logged Link to Post Post Reply Quote i am an idiot
The wire is Light Green with orange stripe. Directechs says a 480 ohm resistor. Connect one leg of the resistor to that wire. Ground the other leg of the resistor.
Thursday, February 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
