How To Wire Directed 415M To InstallGear Actuators?
evetts
Member - Posts: 6
Posted: June 25, 2022 at 11:01 AM / IP Logged Link to Post Post Reply Quote evetts
Greetings all. Having some trouble trying to figure out how to wire this relay to the actuators. This is on an older ford truck without factory power locks. I installed an Avital 3100LX, and now I want to use the power lock feature in the alarm to add power locks to my truck. So I plugged the 3 wire connector from the relay into the alarm, and when I arm and disarm the alarm, the 451M clicks, so I think we’re good there. My question is, how do I wire this relay to the actuators? The actuators only have two wires each- a blue wire and a green wire. The relay has 5 wires coming out of it- the violet one obviously goes to constant 12v, but I can’t figure out the other wires- white, green, blue, brown (all with black stripe). I want to assume blue to blue and green to green and the others are unused? I would assume one would go to ground?
Yes the relay came with instructions but they suck, so any advice is greatly appreciate!
mgoetz74
Silver - Posts: 424
Posted: June 25, 2022 at 1:58 PM / IP Logged Link to Post Post Reply Quote mgoetz74
white and brown to ground, blue and green to the blue and green of the actuator. purples to 12+
evetts
Member - Posts: 6
Posted: June 25, 2022 at 6:45 PM / IP Logged Link to Post Post Reply Quote evetts
Awesome, thank you so much!
Saturday, November 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
