2000 Chevrolet S-10 Blazer, Compustar CS2WQ900-AS, Peer Review Wiring
cooterjenkins
Member - Posts: 9
Posted: November 27, 2024 at 3:23 PM / IP Logged Link to Post Post Reply Quote cooterjenkins
Some years ago, I tried to install a Viper 4706V into my Blazer without checking in here first to have someone look at my proposed wiring. Due to that, there's a very real chance that I bricked the brain for that unit. After not having a remote start for the 3 years or so since I did that, I thought I'd give it another go, only this time with Compustar.
The controller is a CM900-AS, and I'm looking to have someone look over the wiring for this truck to make sure, this time before I do the install, that I have everything laid out correctly.
I got a Blade-AL and the iDatalink ADS-USB cable to write the firmware and the programming to the controller, mostly to overwrite the Passlock II system in the Blazer. The Blade also outputs a tach signal, but I've come to learn the signal may not be very reliable. I'd previously ran a wire from the tach output wire located in the 32 pin Red plug (Pin 20) under the hood into the cab, so I can use that if necessary.
I might have some follow-up questions about parking light output, and which wire to use (CM2 vs CM3), and using only the Tan (-) wire at the BCM for door trigger input.
Thanks for the help, it's always appreciated.
2000 Chevrolet S-10 Blazer, Compustar CS2WQ900-AS, Peer Review Wiring -- posted image.2000 Chevrolet S-10 Blazer, Compustar CS2WQ900-AS, Peer Review Wiring -- posted image.
lee.lopez
Copper - Posts: 300
Posted: November 29, 2024 at 11:58 AM / IP Logged Link to Post Post Reply Quote lee.lopez
For the most part this looks good.
Just a few things: The Red/white at the ignition harness should just be red. Brown is common at the parking lights or BCM but should be light blue at the switch. Tan is the driver's door trigger only. If you want all doors covered, diode isolate and connect all at the BCM.
cooterjenkins
Member - Posts: 9
Posted: December 04, 2024 at 4:36 PM / IP Logged Link to Post Post Reply Quote cooterjenkins
Thanks for the info Lee, appreciate it.
I intend to only use the TAN (-) B4 wire in the BCM as dome light supervision.
Only other question I have is this: is there a reason to use the green/white (+) wire in the CN-1 harness vs. using the green/white (-) wire in the CN-3 harness? Just preference of which polarity is more available or what is the deal here?
lee.lopez
Copper - Posts: 300
Posted: December 04, 2024 at 5:23 PM / IP Logged Link to Post Post Reply Quote lee.lopez
Yes, exactly. Use whichever is more convenient.
cooterjenkins
Member - Posts: 9
Posted: December 31, 2024 at 5:29 PM / IP Logged Link to Post Post Reply Quote cooterjenkins
Lee -
Thanks for the advice. Wanted to come back to say this install went perfectly, and to thank you for your help.
One weird thing that I can't exactly figure out: my HVAC doesn't seem to start up until the vehicle has been taken over by the key for some reason. Everything else is working, parking lights, stereo is on, basically everything except for the blower motor. The way I understand the accessory wires is that the orange wire in the ignition switch harness has control of most of the electronic systems, including HVAC. There is a brown wire in the ignition harness that's marked second accessory, but in researching this I think this wire controls retained accessory power, secondary to what the orange wire carries.
The Blazer has a second ignition that must be wired with the Compustar's blue wire in the CN-1 harness, as set by jumper in the controller to ignition.
Any ideas why the defrost isn't working until the key takes over the vehicle?
lee.lopez
Copper - Posts: 300
Posted: January 01, 2025 at 8:01 AM / IP Logged Link to Post Post Reply Quote lee.lopez
You likely need to power the brown accessory wire. You can program a POC to option 31 and use that to pulse the door trigger to shutdown RAP when remote start shuts down.
Wednesday, February 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
