Compustar CS5200, 1994 Mercedes E320
watut
Member - Posts: 7
Posted: December 18, 2024 at 9:18 AM / IP Logged Link to Post Post Reply Quote watut
Hey all. I have a compustar cs5200 laying around the garage that i want to install into a 1994 mercedes e320 sedan. I dont really care for the remote start, i just want to hook up the keyless entry. Would this be a straight forward install under the rear seat? Do i need diodes etc? Any tips on wiring would be appreciated
chev104275
Gold - Posts: 1,436
Posted: December 18, 2024 at 11:07 AM / IP Logged Link to Post Post Reply Quote chev104275
I've never done one of these cars but it shouldn't be too bad just doing keyless entry. You will need a few relays for the locks. although I'm not sure about the CS5200 being able to do a 2 second pulse for the locks.
1994 Mercedes E-Class Alarm, Remote Start, Keyless Entry Wiring Information
Constant 12V+     Red      Ignition Switch Harness
Ignition     Pink/Red      Ignition Switch Harness
Parking Lights     Gray/White L      And Gray R at Light Switch or Alarm Module
Factory Disarm     Green/Yellow (-)      Under Driver's Floor Mat
Door Lock     Blue      Driver's Kick Panel
Door Unlock     Blue      Vacuum Door Locks
Vacuum door locks
Platinum - Posts: 7,828
Posted: December 18, 2024 at 5:40 PM / IP Logged Link to Post Post Reply Quote kreg357
Yes, the CM5200 can do a 2.5 and even a 3.5 second lock output. I did one of these cars a while ago with a CS800 with a 3.5 second output and a Directed 451M module. Made the lock wire connection at the pump under the rear seat. Passing wires thru to the trunk was a challenge...
watut
Member - Posts: 7
Posted: December 18, 2024 at 5:55 PM / IP Logged Link to Post Post Reply Quote watut
Do you recall which wires go where
Posted: December 18, 2024 at 6:56 PM / IP Logged Link to Post Post Reply Quote kreg357
I don't think I took any photos of that install. I'm out of town right now so I don't have any notes/paperwork available. The customer only wanted RKE. I was able to get power and Parking Lights under the rear seat and ran the antenna up by the rear window. Here is the lock info from another source :
Power Door Lock (All)   BLUE   DRIVER KICK PANEL OR
Power Door Unlock (All)        AT SUPPLY PUMP UNDER REAR SEAT
I do remember spending a lot of time doing wire ID to get everything working right.
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
