trunk release help for concept 200
Copper - Posts: 93
Posted: June 23, 2003 at 11:35 AM / IP Logged
this is all very new to me, so i'm gonna sound like a complete newbie.
i want to connect the auxiliary A (trunk release) of my concept 200 alarm system on a 1999 Civic.  the wiring diagram for the concept 200 shows that i should be using pin 16, grey/violet ch.A out -.   what would i need (relays, solenoids), and how would i hook this up to my trunk release?
should it be pulsed, or latched?
Platinum - Posts: 12,488
Posted: June 23, 2003 at 12:33 PM / IP Logged
You will need to get a trunk release solenoid and install it into the hatch reelase cable. Then wire up a relay like this: http://www.velocitymotorsport.com/images/install_notes/N2P.jpg
80085
Copper - Posts: 93
Posted: June 23, 2003 at 12:59 PM / IP Logged
thanks jeff.
a few more questions.  what will the solenoid actually do, and where can i get one?  any idea how much they go for as well?
Posted: June 23, 2003 at 1:13 PM / IP Logged
The solenoid will be the device that actually pulls the cable when you press the trunk release. I don't ever recall a Civic with OEM factory power trunk release so you will need to install one.
80085
Copper - Posts: 93
Posted: June 23, 2003 at 11:07 PM / IP Logged
would i still be able to use the existing latch to open my trunk as well if i install a solenoid into the release cable?
Posted: June 23, 2003 at 11:11 PM / IP Logged
Yes, you would not know that you have a trunk release solenoid installed when you pull on the OEM lever.
