door locks
jurabals
Posted: July 17, 2003 at 1:36 PM / IP Logged
I need help in finding the wires between my door lock switch and the motor. can someone give me a diagram starting from the door wires in the kick panel through the door harness. Does the door wire start from the switch-->motor-->goes through the door harness or from the motor-->switch-->then through the door harness. I'm trying to install a second unlock pulse on my car so that the first push of the unlock button will only unlock the driver side and the second push will unlock all doors. Please help. Thank You.
djfearny2
Silver - Posts: 810
Posted: July 17, 2003 at 4:08 PM / IP Logged
the way it works is switch motor and either just motor wires in the door or in most cases both. email me with car make and stuff and i will help you out.
Jon
Installer/Help Technician
---coral springs florida---
draasch
Gold - Posts: 2,172
Posted: July 19, 2003 at 4:01 PM / IP Logged
what is the yr make and model of car??????????????????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
