95 Jeep Grand alarm wiring
2bmodded
Posted: July 23, 2003 at 6:02 PM / IP Logged
  I have a 95 JGC with a factory alarm, but it does'nt have a led indicator.  I purchased a led scanner to solve this.  I was told that with my keyless entry I just need to connect to the doorlock wire that is 12volt when unlock and grounded when lock.  I checked the diagrams at this site, but no luck.  Any help of any wire that meets this requirement  is appreciated.  Thanks in advanced.
draasch
Gold - Posts: 2,172
Posted: July 23, 2003 at 9:59 PM / IP Logged
Make:   Jeep
Model: Grand Cherokee
Year:    1993-95
This Database Was Last Updated On:    6/9/03
Index #: 8963
Alarm
Constant 12 volts RED / WHITE FUSED AT 40 AMP AND PINK/BLACK FUSED AT 60 AMP
Ignition 12 volts DARK BLUE/GRAY IGNITION SWITCH HARNESS
Starter YELLOW/DARK BLUE IGNITION SWITCH HARNESS
Dome Light YELLOW (-) DRIVER KICK PANEL OR COURTESY LIGHT
Trunk Pin Switch GRAY/BLACK (-) LIFTGATE PIN SWITCH *
Parking Lamp DARK BLUE/RED (+) HEADLIGHT SWITCH OR AT FUSE BOX
Power Lock ORANGE / VIOLET DRIVER KICK #202
Power Unlock PINK/VIOLET PANEL
* 1993 GRAY (-) At Liftgate Switch, VIOLET / YELLOW (-) At Light. YELLOW (-) Door Trigger Should Cover Rear Hatch On All. #202- See Positive Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
