help on installing my alarm
d1crx
Member - Posts: 7
Posted: August 07, 2003 at 7:43 PM / IP Logged
I started installing my alarm today.  I'm pretty sure I hooked up the wires correctly.  I cannot arm or disarm the car but when I listen carefully under the hood the siren is going off very softly.  I was wondering what other connections I would of left out.  Is there anything that goes with the starter wire?  Try to help me out guys.  thanks
mobiletoys2002
Gold - Posts: 1,050
Posted: August 07, 2003 at 7:52 PM / IP Logged
check your ground on the alarm (not the siren) make sure you actually do have a good ground .direct to chassis woulkd be a great connection you may have it to secondary metal and this may not be a ground.
d1crx
Member - Posts: 7
Posted: August 07, 2003 at 8:01 PM / IP Logged
I'm checked the ground and it's pinned to teh chasis of the car.  What else can it be?
draasch
Gold - Posts: 2,172
Posted: August 08, 2003 at 2:28 PM / IP Logged
d1crx wrote:
I checked the ground and it's pinned to the chasis of the car. What else can it be?
make sure you have a ring terminal on the end that is grounded.
it would also help to know what unit you put in and also what kind of car you have....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Laur
Copper - Posts: 65
Posted: August 10, 2003 at 2:07 PM / IP Logged
Try to see if you have 12 V between + and - then check that the + from ignition is not a direct + ( all measurements on alarm brain ).
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
