dei 530t problem
rghrdr18
Member - Posts: 28
Posted: August 18, 2003 at 10:16 PM / IP Logged
i installed the dei 530t into a 96 eclipse gst. i hooked up all the wires except the grey wire. now the windows are hooked up to channel 4 on a dei viper550esp, that works fine. the only problem is that instead of the windows rolling up when i arm the system, they roll up when i turn off the ignition. what could be the problem? please helpdei 530t problem -- posted image.
sufferrar
Copper - Posts: 190
Posted: August 19, 2003 at 8:46 AM / IP Logged
Check where you connected the orange wire in the 530t module. it should got to the negative when armed output of the alarm (orange wire on the alarm unit).
"I'm So Loud It Hertz"
rghrdr18
Member - Posts: 28
Posted: August 19, 2003 at 9:35 AM / IP Logged
cool, i check that, thanks
CutDog504
Silver - Posts: 643
Posted: August 24, 2003 at 12:43 AM / IP Logged
I know exactly what yer problem is. You are getting feedback thru the starter kill relay. You need to diode isolate the starter kill relay from the orange wire on the 530t. To accomplish this task, you will need to connect a diode to the orange wire from the 530t, and put a diode on the orange wire coming from the starter kill relay. Make sure that the band side of the diode faces away from the starter kill raly, and away from the 530t. Tie together the 2 band sides of the diodes and connect this to the orange wire coming from yer alarm brain. So now you should have made a "Y" connection with th two band sides on the same side of the y facing the alarm brain.
