SRS light on Acura 3.5
csorb
Copper - Posts: 317
Posted: September 18, 2003 at 10:23 AM / IP Logged
Hi. I read the thread about clearing the SRS light that is easily triggered on Hondas and Acuras. We had this on a 2001 Acura 3.5. There was a link given then that seemed to work. The link given then doesn't seem to work anymore. If anyone has any info, it'd be appreciated.
Platinum - Posts: 12,488
Posted: September 18, 2003 at 10:43 AM / IP Logged
Try this and let me know if it works
airbag
Member - Posts: 10
Posted: September 24, 2003 at 2:22 PM / IP Logged
The SRS clearing procedure from the link is not correct. Here is the right method. There will be a YELLOW 2 pin connector in a blank cavity in the fuse panel. It is less than 1/2" square and normally has green wires. Ignition off, unplug this connector from the fuse box. The procedure requires shorting and unshorting the terminals in this connector and a momentary switch in the jumper wires used will make it much easier. Step 1: Short the terminals and then turn ignition on. Step 2: When the SRS lamp goes out - unshort terminals. Step 3: When SRS lamp comes on again short terminals. Step 4: when SRS lamp goes out unshort. Successful code clear indicated by 2 rapid flashes of SRS lamp and then it will go out and stay out. Cycle ignition again to verify codes cleared and lamp out.
Bob Edwards - Airbag Service
profuse007
Gold - Posts: 2,015
Posted: September 24, 2003 at 5:53 PM / IP Logged
thats awesome airbag. wonder why you call yourself air bag. LOL
Houston,TX
csorb
Copper - Posts: 317
Posted: September 25, 2003 at 3:42 PM / IP Logged
Thanks so much airbag. Now why didn't the dealer know that? hmmmmm.
airbag
Member - Posts: 10
Posted: September 25, 2003 at 9:53 PM / IP Logged
Every Honda/Acura from 95 to 03 (some 94's) uses this method for SRS codes. The location of the diagnostic plug can be different between models. The dealer techs use a scantool and may not be willing to reveal the manual method I described. I guess they want the work for themselves?
