Remote start, accessing directechs.com?
siman35
Member - Posts: 7
Posted: September 19, 2003 at 6:56 PM / IP Logged
Hello All,
I just got asked by a guy in town that just bought a 2004 Mitsubishi Lancer Evo 8 if he could do a remote start on it. This guy has got a razor sharp memory so I told him that he could as long as he left it in neutral. Now the thing is, he has got a turbo timer on it (with a harness for it) and he wants to have starter kill. I have installed remote start on turbo vehicles (a WRX being my most recent) but not one that had a turbo timer installed on it. Is there anything that I need to know prior to my doing this (I told the guy that I would do it on monday). I also came across this site that Directed Electronics has called ( www.directechs.com) and I was wondering what I would have to do to gain access to this site. I'd only plan on using it very little seeing as most of what I need to know is on here. I think it would do good to know everything else that is not on here. Anything that you guys/girls could tell me about this is greatly appreciated. Thanks!
Joe Astor
JWorm
Platinum - Posts: 2,208
Posted: September 19, 2003 at 9:11 PM / IP Logged
I hope you realize you are opening yourself up to a potential lawsuit by installing a remote start designed for automatics onto a standard vehicle. What happens when his "razor sharp memory" fails him and he remotes starts his car into a building or a kid and someone dies. Our country is lawsuit happy, so don't be surprised if you are part of one.
As far as the WRX goes, you could have hooked up a wire at the cars ECU to the remote starter that would prevent it from attempting to start in gear.   Its shows ground in gear, positive in neutral. Hooking it up to the hood input of the remote start prevents it from starting in gear. Very few cars have a wire that acts like that. I have no idea if an Evo does.
As far as getting a password to Directechs, I doubt you are going to get someone to give you their password.
12volts      white       +       ignition harness
Starter      BLACK / YELLOW       +       ignition harness
Second Starter      N/A
Ignition      BLACK/ white       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      blue/black       +       ignition harness
Second Accessory      blue/white       +       ignition harness
Notes: Not required for remote start.
Keysense      blue              ignition harness
Notes: The wire rests at ground with the key out of the ignition cylinder, and goes to an open circuit when the key is inserted.
Power Lock      purple       -       driver kick, door harness
Power Unlock      lt. green       -       driver kick, door harness
Parking Lights+      grn/yel (L), grn/wht (R)       +       wht plug bottom of fuse box
Reverse Light      brown       +       driver kick, harness to rear
Door Trigger      white       -       wht plug bottom of fuse box
Dome Supervision      use door trigger
Trunk/Hatch Pin      GREEN/ orange       -       light in trunk
Factory Alarm Disarm      gray       -       driver kick, door harness
Tachometer      BLACK / YELLOW or BLACK/ green       ac       either ignition coil
Brake Wire      green       +       brake pedal switch
Parking Brake      blue/red       -       parking brake switch
Horn Trigger      blue/red or red       -       steering column
Notes: It is blue/red on the standard models and red on the Evolution VIII models.
Immobilizer Bypass Module:     Required: Yes     Type: Transponder     Part #: 555U
Notes: Only the Evolution VIII models have the immobilizer.
nighthawk2k
Copper - Posts: 116
Posted: September 20, 2003 at 10:29 AM / IP Logged
I wouldn't install the remote start unless your doing a clifford manual transmission remote start. There is a chance that he will lend the car to someone and he'll go to install it and it will drive and hit someone or hit another car.
Tommy
-Clifford/Directed/Alpine-Audio & Security-
New York InstallerRemote start, accessing directechs.com? -- posted image.
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
