Autopage RS-750LCD
jlaudioholic
Posted: July 16, 2002 at 1:23 PM / IP Logged
I have a Autopage RS-750LCD alarm that I tried to install in my 1996 camaro.  The camaro already had a factory keyless enty alarm system.  I used a web site that show how to insall an alarm on this paticular car and tapped into the specific wires it instructed to tap into.  After hooking up all these conections including door lock relay, trunk , and hoop pin switch I decided to try it out(note: I did not hook the starter kill relay, or the remote start relay either).  The lock, unlock, and trunk functions all worked, but the car absolutly would not start with the key!  Is this because I still have the existing factory alarm, or because I did'nt hook up the starter kill relay?  If its because the factory alarm is there any kind of module I can buy to by-pass the factory system?  Any replies would be of great assistance.
Thanks,
John
jlaudioholic
Posted: July 17, 2002 at 8:32 AM / IP Logged
can anybody help me on this?
Autopage RS-750LCD -- posted image.
Platinum - Posts: 12,488
Posted: July 18, 2002 at 7:22 AM / IP Logged
Did you end up cutting the starter wire in half and not install a relay ?
jlaudioholic
Posted: July 21, 2002 at 11:56 AM / IP Logged
I just did'nt install a starter kill relay at all.
Posted: July 21, 2002 at 10:02 PM / IP Logged
Did you not bypass the VATS system ?? How did you do this ? The car won't start if the VATS sysetm has been cut or deactivated.
