Does the hood pin switch set off alarm?
cpgoose
Gold - Posts: 1,098
Posted: July 17, 2002 at 9:40 AM / IP Logged
Hi,
Ok, I know that if the car is remotely started, and the hood is opened (with hoodpin switch installed),
the car will shut off.  BUT...if the car isn't running, and is armed, and they (theives) pop the hood,
does it set off the alarm like it would if you opened a door or the trunk?
Thanks!
J3adSeed
Member - Posts: 23
Posted: July 17, 2002 at 10:03 AM / IP Logged
i thought that was the whole point.  why don't you get in the car, arm the alarm and pop the hood and find out.
TheRapture
Copper - Posts: 208
Posted: July 17, 2002 at 11:28 AM / IP Logged
yes it will sound the alarm.... try putting your window down... closing the door, setting the alarm... reaching in and flipping the hood switch ... then going out and moving the hood up so the pin makes contact... WAAAAA WAAAAAA WAAAAAA... GOD THATS LOUD!!!!!!!!!!
cpgoose
Gold - Posts: 1,098
Posted: July 17, 2002 at 11:35 AM / IP Logged
Oh...I guess I should have mentioned that I don't have the alarm yet...I'm researching.  Oops.  Just wanted to learn what it did first.
TheRapture
Copper - Posts: 208
Posted: July 17, 2002 at 12:55 PM / IP Logged
if i was your boss... I'D FIRE YOU!
cpgoose
Gold - Posts: 1,098
Posted: July 17, 2002 at 1:08 PM / IP Logged
um, ok.  was that in reference to something in particular, or are you just venting?
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
