remote start 2000 jeep cherokee
tjbhoward
Member - Posts: 7
Posted: November 14, 2003 at 7:36 PM / IP Logged
I just installed an Audiovox remote start/ keyless entry on my 2000 jeep cherokee. The lock/unlock function works via remote but the reciever will not even recognize the "remote start" command via remote. Any suggestions? Thanks
cwagner17
Member - Posts: 27
Posted: November 15, 2003 at 12:59 PM / IP Logged
What Audiovox system did you install?
tjbhoward
Member - Posts: 7
Posted: November 15, 2003 at 3:32 PM / IP Logged
It was the Audiovox AARS-5CS Remote Start and Car Finder
Moderator - Posts: 12,488
Posted: November 15, 2003 at 5:35 PM / IP Logged
Did you program the tach as well as install the hood pin wire ? Does the Jeep even attempt to start ?
tjbhoward
Member - Posts: 7
Posted: November 15, 2003 at 7:10 PM / IP Logged
I broke the hood pin switch during install, but did connect to the positive on the underhood light. The tach wont program. The system acts like the control switch is off in both positions. ( It doesn't do anything at all when given the remote start command via remote.) Thanks for all the input so far.
profuse007
Gold - Posts: 2,015
Posted: November 15, 2003 at 8:10 PM / IP Logged
audiovox have a switch thats need to be complete(plug in the switch). unlike DEI theres a initiate ground wire on the main harness, audiovox have this switch you need to plug in.
good luck, post your result....
Houston,TX
tjbhoward
Member - Posts: 7
Posted: November 16, 2003 at 10:57 AM / IP Logged
I fixed it!! I was on the wrong hood light wire. Thanks for all the help.
tjbhoward
Member - Posts: 7
Posted: November 22, 2003 at 8:53 PM / IP Logged
I installed an audiovox remote start on a 2000 jeep cherokee and now something is draining the battery.  Everything was working but the morning after the install the battery was dead and it wont hold a charge. Any ideas about what could cause this? Thanks
Tommy Howard
jrilla
Gold - Posts: 1,498
Posted: November 22, 2003 at 11:08 PM / IP Logged
Did you install an anti-grind relay?
How did you interface the doorlocks? databus interface module or relays?
What bypass module did you use if you have a gray key?
Did you power two devices using a single (-) out when running wire? You should always diode isolate the devices when doing so.
J Rilla
Owner/Installer
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
