2004 excursion dsl. need help
n2hvq
Posted: November 20, 2003 at 1:16 AM / IP Logged
need to find colors and location for tach. sensor wire, and wait to start (glow plug sensor) wire.
n2hvq
misterjimbo
Silver - Posts: 535
Posted: November 20, 2003 at 5:49 PM / IP Logged
for the tach use the lt green white it is taped to a thick wire harness and there are four other wires there as well. the harness is behind the fuse box and to the left a little. i never use the wait to start light because all the units i use have a wait to start function in the menu.
birdondubthreez
Member - Posts: 21
Posted: November 21, 2003 at 12:20 PM / IP Logged
You can go to any igniton coil and use the wire that is NOT red-light green or you can go right behind the hood release there is 4 wires taped behind that. As far as the wait to start there isnt one you will have to use dei part# 528t and the following diagram.    http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1091.pdf
BiRdOnDuBtHrReEz
n2hvq
Posted: November 21, 2003 at 8:33 PM / IP Logged
Thanks very much for the reply...will try those colors....start module has delay avail. but it is excessive on the new 6L diesel.  when warm no delay needed (hardly 1sec.)
Much appreciation
n2hvq
birdondubthreez
Member - Posts: 21
Posted: November 22, 2003 at 1:18 PM / IP Logged
With the pulse timer relay it will allow you to adjust it from 0 to 90 seconds
BiRdOnDuBtHrReEz
