dei on 02 silverado (-)shutdown tripped
douglass
Posted: November 24, 2003 at 12:04 AM / IP Logged
i installed a dei add-on on a 02 silverado and every time i hit the button it tries to start but then dies and the security is right the shutdown diagnostics flashes 6 times (neg) shutdown is what the book says          any help would be appreciated DOUGLASS
tuneman
Member - Posts: 43
Posted: November 24, 2003 at 1:08 AM / IP Logged
By saying dei add on, do you mean remote start only? If so, did you use a bypass module?? If not, the PasslockII can be easily bypassed without a module.
profuse007
Gold - Posts: 2,015
Posted: November 24, 2003 at 1:09 AM / IP Logged
check your tach wire and learn
passlock need to be bypass if not done already
Houston,TX
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
