2000 Acura TL Add-on remote start
jiggabo4u
Member - Posts: 17
Posted: December 04, 2003 at 12:57 PM / IP Logged
I have a 2k Acura TL.And I want to add a remote start to my OEM alarm and stuff....Anyhow. Can I use the Panic output from my factory module as a trigger for an add-on remote start?Or do I have to buy the systems that require you tohit the lock button 3 times or some sequence like that?
Thanks!
Johnathan
jiggabo4u
Member - Posts: 17
Posted: December 04, 2003 at 3:00 PM / IP Logged
Or does anyone know the location of the "panic" wire?
Platinum - Posts: 12,488
Posted: December 04, 2003 at 3:12 PM / IP Logged
Why would you want to use the panic wire as your remote start activation ? The activation wire on the add on remotes require a (-) trigger. Not sure that the panic function is what you want as it will probably be multiplexed into the vehicle's keyless entry system and door locks.
jiggabo4u
Member - Posts: 17
Posted: December 04, 2003 at 4:24 PM / IP Logged
Ok, I was just wondering. Most Add-on remote startsystem work on Aux output from factory keyless entry.I don't think that my TL has an aux. output. Thatswhy I was wondering if its possible to use the panicoutput. But your right, it would be multiplexed.Is there an aux output? Or what are my other options?
Thanks!
jiggabo4u
Member - Posts: 17
Posted: December 30, 2003 at 12:22 AM / IP Logged
I tried to install an Add-on remote start tonight but got stumped by the "lock" negative trigger wire. I think that the wiring diagram I have is incorrect.
Does ANYONE know where the location of this wire isin my 2000 Acura 3.2TL?
Thanks!
profuse007
Gold - Posts: 2,015
Posted: December 30, 2003 at 1:33 AM / IP Logged
|       POWER LOCK|BLACK/ blue          |- |passenger fuse box *1       |
|     POWER UNLOCK|orange              |- |passenger fuse box *1       |
*1 Located in a green 20-pin connector. Use the key switch in the passenger door to test.
lol, youre using the driver switch huh?
Houston,TX
jiggabo4u
Member - Posts: 17
Posted: December 30, 2003 at 8:15 AM / IP Logged
yeah, my diagram said drivers door module...I didn't see s**t. And it was the last wire I needed.
Thanks!!!
jiggabo4u
Member - Posts: 17
Posted: December 30, 2003 at 2:47 PM / IP Logged
Is there anything else I need to know about installing my Remote start? Is there only 2 wiring to tap into in the ignition harness? (Ignition#1 & starter)?
Any advice is helpful!
jiggabo4u
Member - Posts: 17
Posted: December 31, 2003 at 8:28 AM / IP Logged
Well, I tried out that wire and it was the correct one....... BUT!
I should of been more specific. Cause those wires lock
and unlock the car, but I don't need to do that, I just wanted my Add-on Remote start to moniter the wire for a negative pulse when I hit lock with my remote. But those wires are only recieve the negative pulse when the switch on the passanger door is hit, not when the remote unlocks the car.
From what I can tell, the alarm sends a positive pulse to the door locks when its locked.
Is there ANYWHERE in my car where a wire gets a negative pulse when I disarm my alarm???
Or can I add a relay to get the positive pulse to also send a negative pulse to my Remote Start???
PLEASE HELP!!!!!!!!!!!!!!!
profuse007
Gold - Posts: 2,015
Posted: December 31, 2003 at 4:29 PM / IP Logged
the suckie thing is that you cant use ur FOB to unlock ur door, so u have to use ur key to unlock manually
ur doorlocks should outputtin neg pulse not positive.
check ur remote starter addon they should have specific wires to do those tasks, like disarm, 3rd ign.....
use a relay to pulse ur addon in this fashion
85-lock input (-)
86-12volt constant fuse
30-ground
87-output initiate remote start wire(-)
place a blocking diode to block the lock/unlock switch, so you wont be able to start with the switch at the door panel.
Houston,TX
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
