94 Nissan Remote start
JohnnyK705
Posted: December 13, 2003 at 5:18 PM / IP Logged
I have a 97 Nissan Altima, I just installed a crimestopper cs-2011 IV. The automatic locks work with the factory switchs, but not with the alarm remote, the diodes are in place and are wired (-) correctly. [lock is a grey wire on right side of steering column and unlock is a purple wire that I tapped into the left front door] Also I am not sure how to bypass the stock security system, the stock system doesnt have any remotes, just the word security with a blinking red light. I I believe I am supposed to use the orange and black wire, and I think I am supposed to connect it to the green and yellow factory disarm GRN/YEL (-) that is located at the smart entry cont unit, but am not quite sure where that is. Am I supposed to ground out any wires if I dont use them. When I hit the remote start the car starts but the siren is also going off with it. I ve installed several alarms and am getting frustrated with this one, not sure, maybe brain is bad, please help me
I have left the following wires disconnected
       Pink to glowplug                                          ONLY for diesels
       blue (-) hood or trunk switch
       Violet (+) door switch
       Red for door lock relays
       ORANGE / black (-) oem disarm
       Orange (-) armed output (500ma)
       Blue/White (-) passenger unlock                   Optional
       Blue/black (-) IGN or Aux #2 (500ma)
       GREEN/ red aux output or (-)map output           Optional
       BLACK/ White (-)neg Dome Light (500ma)        Optional
       BROWN / White (-) horn honk (500ma)               Optional
       Pink/White ignition or accessory #2 output
Johnny K
jrilla
Gold - Posts: 1,498
Posted: December 13, 2003 at 8:20 PM / IP Logged
POWER LOCK gray/blue
POWER UNLOCK gray/red
Located at door lock timer which is a blk or grn box located right of fusebox behind a silver module or up high in the drivers kick behind a silver module, depending on model. Two plugs, white and black. The wires needed to control locks are in the black plug.
Factory ARM lt. GREEN/ red
Factory DISARM GREEN/ YELLOW
in the harness from drivers door. Hook your ORANGE / Black to the disarm wire, and diode isolate your lock wire with band of diode facing the unit and then go to lock and the arm wire. Arming is optional.
J Rilla
Owner/Installer
