02 camry keyless entry upgrade
Geeque
Silver - Posts: 310
Posted: December 23, 2003 at 9:11 AM / IP Logged
Its one or the other, unfortunately.02 camry keyless entry upgrade -- posted image.
Gary Kline
MECP Master Technician
serialthrlla
Copper - Posts: 57
Posted: December 23, 2003 at 10:27 AM / IP Logged
you could maybe ask the dealer, sometimes they have some add ins
Scott35
Silver - Posts: 258
Posted: December 23, 2003 at 10:30 AM / IP Logged
If you have the Toyota Rs3200 system, they have an upgrade setup for it, which can be found on ebay for a decent price.
Tacomacrew
middleman2u
Posted: December 23, 2003 at 4:58 PM / IP Logged
We do them all the time with the Code Alarm F30 OEM keyless entry upgrade module. They interface with the factory remotes and work great. It will have an onboard shock sensor, Starter disable relay, and flashing light output. Definately the best unit out there for that purpose.
Sean
auex
Platinum - Posts: 5,041
Posted: December 23, 2003 at 6:19 PM / IP Logged
There are many keyless entry upgrades out there. The company that I work for used to use an omega version, which wasn't bad, but we now use automate, made by dei and is much better. Check This out, it is similiar to what we are using now.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Scott35
Silver - Posts: 258
Posted: December 23, 2003 at 6:29 PM / IP Logged
What do your remotes look like, the toyota add on is all plug in no wires to cut.
Tacomacrew
auex
Posted: December 23, 2003 at 7:28 PM / IP Logged
Scott35, who was your question directed at?
Scott35
Silver - Posts: 258
Posted: December 23, 2003 at 7:33 PM / IP Logged
To dolphin542, He asked how to tell if he had the RS3200.
Tacomacrew
auex
Posted: December 24, 2003 at 3:25 PM / IP Logged
It gets wired into the car, the car is actually what controls the alarm. The remote will lock the door, turning the alarm on, then when you hit unlock the car will unlock the driver's door only, on the first push, disarming the alarm. The second push of unlock the alarm will do nothing, same if you push unlock on the switch. The remote has little to do with how the alarm works, so you can program any factory keyless remotes and it will still work the same.
Teamrf
Gold - Posts: 1,031
Posted: February 09, 2004 at 3:38 PM / IP Logged
You think you blew the wire or the ignition harness? I've never seen a blown wire, you may want to check the fuse under the hood. You may have a blown ignition fuse.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Monday, July 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
