1999 Mercury Sable Door Locks
japanime83
Member - Posts: 13
Posted: January 01, 2004 at 4:55 PM / IP Logged
Ok I have a small problem an I hope somone can help!!!
Car: Mercury Sable 1999
Problem: Door Locks
power lock: (-) negative
power unlock: (+) positive
The problem is that the alarm (Valet, Model 563T "Manul can be found here: http://www.directed.com/guides/manuals/ig/valet/N563T_6-03.pdf ) has two wires in th "door lock harness, 3-pin connector" (located on pg. 15 in the manual) 1-green an 1-blue.
the   Green is    (-) lock  (+) unlock output    and     Blue is  (+) lock   (-) unlock  output
but as I stated above the 2-wires need to see (-) in order to do thier seperate jobs.
example: to lock the power lock wire needs to see (-)    to unlock it needs to see (-)
so does the alarm just send a negative on both wires or does it send a (-) to 1 an a (+) to the other
if so how do i correct it to be negative only!
thanks in advance!!!!!!!!!!!!!!,
kitt
ck auto
Copper - Posts: 257
Posted: January 01, 2004 at 6:46 PM / IP Logged
hi just hook them up  as you need them green lock and blue unlock don't worry about the + because the locks rest a 12v
good luck
kirk
japanime83
Member - Posts: 13
Posted: January 01, 2004 at 7:01 PM / IP Logged
thanks alot kirk!!!!!!
